Old 03-26-2012, 02:23 PM
Stan Dowiat Stan Dowiat is offline
Default Aftermarket Gauges...
Anyone using aftermarket gauges for the oil pressure, water temp and alt? Mine are dead... have been for years several years and acted flakey back even 20 yrs ago... Yea, I'd like it to be original, but I'd like to have them back working but I'm betting it would be simplier to just install one of those under the dash sets...
Do ya'll agree? Are those aftermarket sets any good? Anything to lookout for or brands to avoid?
Old 03-26-2012, 07:39 PM
Mark Brown's Avatar
Mark Brown Mark Brown is offline
Default Re: Aftermarket Gauges...
Might want to check out some of the vendors products. There are several making aftermarket gauge panels to put over the stock dash. I have one that I am gathering parts to put in mine. You may find the problems are not the gauges but the crappy IH wiring that is 30 plus years old.
Mark Brown
1977 SSII, off road rig.
1972 AMC Javelin
2011 Ford F-150
1971 Olds Cutlass
Old 03-26-2012, 07:42 PM
rlogan's Avatar
rlogan rlogan is offline
There are lots of examples of aftermarket guages on this site. Just search dashes or guages. I used Hasting guages. Mechanical oil pressure, mechanical temp, changed anmeter to volt meter and aftermarket gas guage. I kept the original speedometer because I didn't want to get that far into the projest. Others have added speedo and tach. The most work was the fuel guage I had to change the sending unit in the tank. A little fab work and body fill on the original dash insert when well. I feel that qualitiy aftermarket guages are more accurate and dependable than the originals.
Old 03-27-2012, 09:03 AM
fredsterra's Avatar
I removed my outer cover and made a plate to mount the round gages to and reinstalled my outer cover.
My long term plan is to smooth a outer cover and weld a flat plate to cover the retangle holes. The cut for the round gages. And have Mike Moore re-cover with the woodgrain and black overlay. So it will have a more stock look to it.
But my first try at it turned out OK. I didn't want it to look too much like a "Red Neck" Hack Job!
Mark Fredrick
Madisonville Ky
Old 03-27-2012, 02:48 PM
urbex urbex is offline
Is your Scout a Canadian model? I was about to say "wow..never knew you could get a 160mph speedo in a Scout!", but then I realized 160kph is roughly equal to 100mph
'64 Scout 80 - rock crawler, LT1/TH400/D300, Dana 60 front/Dana 70 rear
'96 Jeep Grand Cherokee - expedition rig
aftermarket , body , dash , dead , find , fuel , gas , gauges , hose , mount , neck , oil , panels , parts , red , scout , search , speedometer , tach , tank , vendors , water , wiring , work
Changing factory gauges to aftermarket questions heff General IH Tech 1 12-13-2010 01:30 PM
gauges, stock vs aftermarket uncre8tv General IH Tech 4 09-06-2010 11:44 PM
Scout II Instrument Panel Fabrication and Installation with Aftermarket Gauges MikeInMobile,AL BP IH Knowledge Wiki 0 09-27-2009 07:20 PM
How hard is it to keep/wire factory dash gauges w/ aftermarket wiring harness? BeachBinder General IH Tech 1 08-20-2005 07:21 PM
Aftermarket Gauges? Jason861 General IH Tech 10 07-20-2005 05:12 PM
