Old 04-03-2012, 08:01 PM
FOX2300 FOX2300 is offline
Default Re: Introduction and build thread of my 77 scout
Originally Posted by NC Scout View Post
Welcome to the addiction!! I just removed my engine this past winter for new seals and paint, so I know mostly what you are going through. Although, the engine ran fine, just leaked terribly. Make sure you replace those engine mounts, mine were junk.
Good looking truck, I like the colors, looks like the paint should come out really nice. I look forward to seeing more on your thread.
Mark in Raleigh, NC
Thanks, its nice to see a fellow North Carolinian on the forum. Not that it isnt awesome that this is such a large forum, just cool to meet a neighbor.
Old 04-04-2012, 06:26 AM
Mitch Neal's Avatar
Mitch Neal Mitch Neal is offline
There are a lot of guys in your area. If you are able to make it to the AutoFair at the speedway, you will meet many more! Truck is looking good!
Old 04-06-2012, 06:42 PM
Thanks. I wont be driving my scout by auto fair, but I will definitely come by and meet the club. Im there every year.
Old 04-06-2012, 06:53 PM
dkterra's Avatar
dkterra dkterra is offline
Send a message via MSN to dkterra
Looks like your doing allot of nice work to your rig.
I also noticed it looks like it had a nice factory blue underneath.
1980 Terra 304, needs finished or I'm walk-in!
1979 Scout II 345 Smokey (not my project)
1976 Scout II 345 auto half cab
1976 Parts Scout II 304 auto (I'll NEVER learn!)
1950 IH fridge
Old 04-06-2012, 07:08 PM
Here is the video of the first run on the test machine, I had several lifters that were slow to pump up, so there is a lot of clicking noises. I let it sit over night, and they pumped right up. I was by myself this morning and couldnt get a vid of the final run, but with hot oil it did 55psi oil pressure, 175psi compression, no knocks or noises, and good cam breakin with all 16 lifters pumped up and rotating.
Old 04-06-2012, 07:48 PM
Here are the pics taken during the machining and build. My engine didn't need as much work as I expected. I was planning on a bore job and new pistons, but since my pistons and cylinders measured perfect, I just gave it a light hone on the block and light knurl on the pistons to promote skirt oiling. My heads didn't need much work either, just a basic valve job with new seals, and I took the time to surface them on the deck and exhaust sides. Of course with the damage to the rotating assembly all 8 rods had to be re sized, and the crankshaft ground, oil holes chamfered, and micro polished. The long block is re assembled with new main rod and cam bearings, rings, camshaft, lifters, water plugs, and gaskets.
Old 04-09-2012, 07:28 PM
My pertronix ignition parts came in today. That was the last mail order part, so one more big trip local parts store and I think I will be ready for the install!!!!
345 , body , build , build thread , engine , free , fun , knock , lift , paint , parts , project , rebuild , rust , scout , spring , spring lift , suspension , tires , top , truck , wheels , work
1973 scout ii ....and so it begins.... nandomart General IH Tech 25 10-27-2009 09:44 PM
introduction lostoffroad Sonora Desert Scouts (Arizona) 6 08-16-2009 09:41 PM
Introduction GA_Scout Southeast Binders Association 10 12-21-2006 06:45 PM
