Old 03-22-2012, 03:16 PM
sdowney717 sdowney717 is offline
Default Re: Dished lifter = need new cam?
the only intermittancy of oil flow is off cam bearings that feed each rocker shaft.
Cam has a single drilled hole which only lines up every 180 degrees of turning.
The chart mistakenly says valve lifter tappet flow is intermittent. The cam has a circumferential groove on number 5 cam journal, flow is continuous to the lifters. Technical editors made a mistake when they reviewed this document.
Notice they also show an 'oil pump float', ridiculous. So it floats on the oil surface in the pan?
Old 03-22-2012, 11:35 PM
Eric VanBuren's Avatar
The holes on the ends of the heads are for the turbo/air brake compressor oil supply drain back connections.
Old 03-23-2012, 06:15 PM
Greg R's Avatar
Greg R Greg R is offline
Some engines, as in heavy equipment, tractor, etc., had a pivoting oil pickup with strainer at the end of the suction line. The oil schematic is general in nature, and no matter how many engines you've had, worked on, or years in the profession; one rarely sees them all.
69 800
266 V8/4spd & D18TC/OD
4.27 D30/ D44
'56 S110 240 I6/4spd
'71 1210 345 V8/4spd 2WD
'67 Travelall BG246/4spd 2WD
100 , 345 , 392 , binderplanet , cam , cylinder , dash , diesel , engine , exhaust , hydraulic , idle , intake , oil , oil pan , parts , pickup , problem , pulling , replacement , size , valve , zddp , zinc
IH SV Cam Swap Basics Part 4 MikeInMobile,AL BP IH Knowledge Wiki 0 09-27-2009 07:07 PM
IH SV Cam Swap Basics Part 3 MikeInMobile,AL BP IH Knowledge Wiki 0 09-27-2009 07:05 PM
IH SV Cam Swap Basics Part 1 MikeInMobile,AL BP IH Knowledge Wiki 0 09-27-2009 06:57 PM
Clattering noise revisited again. Mernjohn General IH Tech 16 07-23-2006 04:28 PM
