More info. Are you talking about a vehicle?
64 IH 1Ton,345,T34,T18,Np202,40"MTRs,crawl ratios,61:1,113:1,207:1,375:1,D70 front with ARB & 35 spline chromolly axles,RA15 rear with Detroit Locker,York on board air,custom 200 amp welder. Iraq veteran 04 |
Sorry, I was refering to a tractor.
ops
The 9930 J makes this tractor a 1961 year model. The "J" means it has a Rockford brand foot clutch. The Tractor should be a straight gear drive, no Torque Amplifier (T/A).
Always searching for IH 4300 Transtar Eagle Brougham items....... Cub Cadets...Built for those who know better. |
Thank you Bermuda. I've also found 3 identical tags on the motor,trans,&rear end. The look like screw on tags with a screw head between each#. Looks like this. 7-21-F. I thought I read that to be month-day-year. F meaning 1960. I'm new to this and really not sure.
Thank you for your help. |
A 340 Untility used a lot of odd-ball castings compared to other models of tractors being built by IH at the time. They would have cast several months worth of castings and machined them in a single batch to save set-up time. |
Ooohh. Thank you for all that info. How did you guys know the "9930" was a 1961? Amazing. 100% right about foot clutch and other info. I'm learning a lot, thank you.
On another note, what kind of hyd. Oil should I use for the rear 3 point cyl. & the powersteering. I think they are all part of the same system. |
IH kept track of the first tractor of each model off the finish line the first day of every fiscal month. This also allowed them to keep track of how many of each model was made every year. With just the number portion of the serial number you can pin down the exact month of production and estimate the week and maybe even the day of the month it was made. |
Wow thank you all. So much great info.
| 100 , 196 , 1960 , 1961 , 800 , build , clutch , gear , hose , info , oil , part , parts , pto , rear , tractor , transmission , worth |
| Utility bodies? | Karl Bader | General IH Tech | 5 | 06-14-2011 07:42 PM |
