Old 03-19-2012, 07:06 PM
EagleScout EagleScout is offline
Default 73 scout transfer case swap
I have a 73 scout with the A727 auto and the single speed transfer case. I have found a dana 20 from a local salvage yard, and would like to swap them out. From what I can tell, this should be a simple ordeal - but I have some questions.
My 73 had a spare T-case (single speed), and when I compare the input to the d20, they do not appear to be compatable. I still have access to the donar scout that the d20 came out of, and the transmision output has a set of drive gears on it. As far as I can tell, they are the same transmission model. Here's the question: What do I need to get (if anything) to mate the d20 to my current application. I would rather have all of the parts and attack this all at once rather than get half way into it an find that I am missing something.
Thanks for the advice
Old 03-19-2012, 07:21 PM
Default Re: 73 scout transfer case swap
You need that drive gear off of the other tranny,they are specific to t-cases.If it came off of a 727 it will bolt to yours.You might need drive shafts,I dont know for sure
Old 03-19-2012, 08:20 PM
Dennis Bernth's Avatar
Front driveshaft for sure, back might work, you can try it and see. But the single speed front shaft is quite a bit longer than the one for the Dana 20. Good opportunity to grab both shafts and put in new U joints, then you know your good for a while. I've done that swap a couple of times and both times I used the driveshafts that came with the donor Dana 20.
727 , advice , case , drive gear , find , gear , gears , parts , salvage , scout , swap , tranny , transfer case , transmission , work
'78 scout transfer case problem tdncotton General IH Tech 3 08-24-2010 12:33 PM
1977 Scout transfer case lever pop out of gear Justin Jenia General IH Tech 15 10-24-2006 12:28 AM
Scout II engine swap question. mntgoat General IH Tech 30 01-31-2005 09:05 AM
67 scout transfer case jumps out of gear Joe Mechaley General IH Tech 5 05-25-2004 06:48 PM
