Old 03-15-2012, 07:33 PM
46binder 46binder is offline
Default Big thanks to Bill USN
Thanks to Bill for his help, PM's and phone calls, I have a bench tested EFI setup. Took me awhile, but I did it! Had a problem with the driver for my Windows 7, but got a green 20 on the screen, and all was good. I was worried about the knock sensor, whether the plug would come out but a 8 pt socket did the trick no problem. Got the throttle body adaptor on, but can't find my bolts for the TB, were there special headed bolts or grade 5 bolts with washer sufficient? Hope to time and install dist and start hooking it up, last is the fuel line. Looking forward to fuel injection, couldn't do it without all Bills tutorials and help, thanks Bill!
Old 03-15-2012, 07:46 PM
Default Re: Big thanks to Bill USN
Andy,
It was a pleasure talking to you on the phone and emails, and PM's and .......
Just grab some 5/16 x 2" with lock washers and small flat washers and you should be fine.
If you delete the lock washer then you need to grind about 1-2 threads off the bottom if using the thin transdapt adapter or they will bottom out.
adapter , body , can't find , efi , find , fuel , fuel injection , fuel line , grind , knock , lock , plug , problem , start , throttle , throttle body
Paging USN Bill Robert JetFxr Injection Tech 6 01-18-2010 08:05 PM
Omnibus Land Bill S.22 InTheSkin General IH Tech 5 03-19-2009 01:51 PM
Bill to restrict use of antique vehicles in VA Brian Schermann Old Dominion Binders Association 5 01-12-2006 01:43 PM
