The lines are for the oil cooler originally incorporated in the radiator and the flap is a part of a system for quicker warming of the engine offering a greater exhaust resistance.
1978 Terra glass body 345 727 T20 D44 |
The two lines go to the transmission cooler. Radiator has two bungs on the cold side these go to, or a separate trans cooler, or even both.
The "brake" is a flapper valve that forces the exhaust to run through the intake to warm it in cold weather, passenger side has one the drivers side did not. When closed the exhaust gases run through the "fifth" exhaust port (center port) on the heads, through the passage in the intake manifold, through the drivers side head to the exhaust manifold. This warmed the intake to atomize the fuel better. |
Thanks for the replies! I need to try to connect the lines due to hot Texas summers, but does the "brake" or flap need to be connected to run well?
Nope, don't need it. Headers are better.
1980 Terra 304, needs finished or I'm walk-in! 1979 Scout II 345 Smokey (not my project) 1976 Scout II 345 auto half cab 1976 Parts Scout II 304 auto (I'll NEVER learn!) 1950 IH fridge
Do you know any performance headers that wont break the bank?
| 345 , 727 , binderplanet , brake , cooler , engine , exhaust , fuel , hot , intake , oil , oil cooler , part , performance , question , radiator , scout , texas , transmission , valve |
| Name of fitting for transmission lines | TheGoldenGreek | General IH Tech | 6 | 08-16-2010 11:58 AM |
| Replaced front lines, now no pedal... | noel | General IH Tech | 19 | 11-26-2007 11:21 AM |
| Transmission cooling line | ttwntec | General IH Tech | 8 | 09-26-2007 02:36 AM |
