Old 03-08-2012, 10:35 AM
76 xlc 76 xlc is offline
Banned
Default Re: "dieseling" '75 d200 345
For the '67 model year, VW added an electric fuel shut off solenoid to avoid run-on, after retarding timing and leaning the mixture, two things IC engines don't like, especially air cooled IC, to meet US smog regs.
Does the oxygenated fuel of today create a similar situation on old IHC IC engines?
Old 03-08-2012, 05:17 PM
fibre optic scope stuck in the sp hole will show before and after carbone removal.
fm house; am well aware of supposed timing causing dieseling, its a secondary cause.
the real cause is too much fuel in the comb. chamber./
and that points directly at the owner/operator/driver.
i can, with my excellent- running- well -tuned- IH- torque- monster- v8- 304 engine easily get the engine to diesel, by romping on the throttle as i turn off the engine. its not got a hot spot in the chamber, or way off timing- or a hot running engine...........
ITS GOT A LOT OF FUEL IN THE CHAMBER. so itll do what its supposed to do - ignite and burn.
makes the engine spin forwards or backwards as the case maybe..
case closed.
Old 03-08-2012, 08:10 PM
FMhouse FMhouse is offline
case closed.
that was exactly my point.Retarded timing=too much throttle to maintain idle speed=too much fuel in the chamber on shutdown.cheers.
Old 03-08-2012, 08:45 PM
BO185's Avatar
BO185 BO185 is offline
Dang that's a good idea. I seen one a lowes or home depot it was affordable and pretty nice color picture.
I have to look for one be nice to add to the tool box.
-73 Scout II- GM Vortec 6.0L 4L65E NP241
-73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's
-01 VW TDI Beetle- 50mpg or better
-55 Chevy 210 Delray 235/3sp
-56 Chevy Belair 4 door hardtop*next project* 5.3/4l60/3.08's
LSx swap info
Old 03-08-2012, 09:56 PM
''''''''that was exactly my point.Retarded timing=too much throttle to maintain idle speed=too much fuel in the chamber on shutdown.cheers. ''''''''''''
the more i think about it, i'll disagree. easy enough to test anyways.
go twist the dist so the timing is 15 atc. see if it runs at all.
try10 atc,
try 5atc
without adjusting the idle speed..
even adjusting the idle speed screw to get it at 700, i doubt that tosses enough fuel into the intake to cause dieseling..
friday morning myth busters:
so i ,with engine fully warmed, at operating temps 185*f [on autometer mechanical temp gauge, double checked temp with 2 other thermometers in the radiator].
i checked my engine timing- 10*btdc idle speed 800rpm+-, then
i twisted the distributor ['dizzy' for you backwoods] as far as it would go to retard the timing- checked and saw the timing mark on harmonica balancer about 30 to 40 atc [ quarter past the 0* mark on the timing cover][ thats at 3 oclock position if looking at the engine from the front]
engine still ran- at about 400rpm+_ [didnt bother checking idle speed with a tacometer, I can tell by the sound, being experienced and all...]
, turned it off twice-- no dieseling ,wonder why. its supposed to!!
stepped on the gas pedal as i turned it off- no dieseling.
didnt need to turn the carburetor idle speed screw any to keep it running,
put timing back to the real world [where any IH owner would check at least once since they rescued it from a farmers field back in 1910..]
and as i turned off the ignition, I held the throttle down [ my holley squirts fuel just fine thank you very much] and as the engine stopped it gave a tiny attempt to keep running.. kinda . . did deisel.= lotsa extree fuel!
so that disolves another old wives tale into thin air, about idle speed screw turned all the way in to keep an out of time engine running.
causing any dieseling because of timing . .
[ this of course was tested on a well tuned 304IHV8 engine with 400,000 miles on it, vacuum gauge indicates 19"hg at 800rpm- idle speed, smooth needle, 10 * btdc [initial] static timing, with a -------WAIT NOW!! HOLLEY 500CFM 4412 LIST carburetor..]
your tests may vary of course..
oh with a holley electronic ignition distributor, with ford duraspark cap'rotor conversion,
jacobs wires energy core sp wires all routed seperately in wire looms to the plugs,
autolite 85 plugs, .050 gap,
and 87 octane fuel,
27.7 inches of pressure, 3000 msl, 10% humidity, 75*f.
45 psi in the BFG -AT KO 31.10.50x 15 tires load range C
Old 03-09-2012, 04:07 AM
hacri's Avatar
hacri hacri is offline
I'm not quite sure about the fuel in the combustinon chamber.....in the old WW2 2.5t GMC(cckv) trucks the manual say to floor the gas pedal as you stop the engine, this to leave gas in the combustion chamber for easyer starts. It has to do with combustion chamber temperature, as the spark plug is not firing, but it is a self combustion(as is "pinging")
1978 Scout II 304(soon 392)/727/dana 20, Holley Pro-Jection
1979 Scout II 304/t19w/dana 20
1969 Scout 800 Frame
345 , carb , carburetor , cooler , d200 , engine , fuel , holley , hot , idle , ignition , info , intake , lock , oil , piston , plug , problem , spark , start , tbi , timing , travelette , turn , vacuum
BOOSTED 345 engine build opinions cycomick General IH Tech 3 11-15-2009 01:01 PM
'71 304 vs. '75 345. Power output differences. 350IH80 General IH Tech 3 06-04-2009 05:33 PM
392 ic swap for 345 also 392 casting # id jschuepb General IH Tech 3 07-05-2007 09:48 PM
304 vs 345 Pavegunner53 General IH Tech 28 01-02-2007 01:02 AM
392 heads on a 345 grivera General IH Tech 4 11-18-2004 01:39 PM
