Old 03-06-2012, 08:26 PM
hammer hammer is offline
Default trans help please
i got a 1979 terra . i rebuilt the carb, new distributer, pertronix ho 181, flame thrower coil, replaced valve gaskets, new plugs ,new muffler and pipes,and ajusted the steering box . been driven it the past week with no problems , went to go to store got in it and no reverse !!!!!!!!!!!!! where do i start
scouts are not a project they are an obsession !!!!
Old 03-06-2012, 08:37 PM
mhouston mhouston is offline
Default Re: trans help please
How about forward? Does is engage any of the gears? If not, it's likely the front pump in the transmission. It'll have to be pulled and replaced if so.
Old 03-06-2012, 08:46 PM
scoutboy74's Avatar
This is an auto trans, I assume? You should specify. The first step is always to verify the fluid level. Park on level ground. Bring the engine up to operating temp. Move the gear selector lever slowly through the gear positions, then place it in neutral. With the engine idling, get out and pull the dipstick. If the level is below the safe range, add Dexron fluid in small amounts and keep checking until the level is at the top of the safe range.
If the fluid level checks out good and still no reverse, pay particular attention to how the rig takes off in both breakaway 1st gear (selector in drive) and also manual 1st gear (selector in L1). Chances are there is an issue with your low/reverse band and/or the low/reverse apply servo. Determining this will involve removing the fluid pan. You may be able to restore function by adjusting the band tension. It could just be way too loose, but the only way to access the adjuster is with the pan removed. Doing so makes one hell of a red fluid mess everywhere. But, if you don't know or can't remember when this trans was last serviced, it is most likely long overdue for some basic maintenance, including band adjustments, new filter and fresh ATF. The band adjustment procedures are outlined in the Truck Service Manual.
Trever Whetzel
Fat White Boys
Binder Recovery
& Rehabilitation
SHOP NORTH
Old 03-07-2012, 07:20 AM
J.D.Oldham's Avatar
J.D.Oldham J.D.Oldham is offline
The reverse band may have broken. I've broken two myself. There is a beefed up reverse band that I like, but you do have to do a complete tear down to replace. Drop the pan and have look see, there may be a wedge looking thing in the pan.
78 Scout II 4" lift 36" TSL, 304, locked & locked
Hunter's 1966 Travelette, 304 4 speed track-lock
76 Scout II 32" 400 MOPAR, broke
2- 74's and 76 Terra
18 pass. school bus for storage(soon to be a woods cabin)
Old 03-07-2012, 05:23 PM
dkterra's Avatar
dkterra dkterra is offline
Send a message via MSN to dkterra
I assume your shifter cable has not slipped out of adjustment or having issues?
Just thought I'd throw that out there.
1980 Terra 304, needs finished or I'm walk-in!
1979 Scout II 345 Smokey (not my project)
1976 Scout II 345 auto half cab
1976 Parts Scout II 304 auto (I'll NEVER learn!)
1950 IH fridge
Old 03-09-2012, 06:42 PM
thanks every one . yes its a auto trans . fluid is good shifts fine in drive just no revers. i need to buy service manual
1979 , box , broke , carb , coil , engine , filter , fluid , front , gage , gear , gears , ground , manual , pertronix , pump , restore , reverse , start , steering , terra , top , transmission , truck , valve
Need help: T-19 trans and possible clutch issue SC76Scout Southeast Binders Association 9 01-03-2012 10:28 AM
Trans is Back IN!!!! JWaters General IH Tech 9 05-12-2009 03:21 PM
Losing 2nd after trans removal (T19)? Darel General IH Tech 6 09-11-2006 01:38 PM
RPT Trans mount? AnArticulateMatter General IH Tech 6 04-27-2006 10:10 AM
