I have used radiators from all models 69-75 back and forth between yearswith no issues. I did a thread on a wagonmaster and I put a radiator out of a 75 pickup in it and it was a 73. I also put a radiator in a 74 out of a 70 etc...74 and 75 have a different depth fan shroud, scout2 fan shrouds are narrower. D series radiators are winder than scout2 I could measure as I have both on hand on the shelf but don't know the measurements of the top of my head.
80 4wd Terra Diesel-az rig 78 (345)4wd scout2 RHD CO 75 150 travelall 4wd TX 74 200 (345)4wd p/u KS 74 100 (392)4wd T-all Cali/mex 73 1110 (Olds 350)2wd short stepside MO 63 1/2 cab 80 plow scout A few parts rigs |
I just printed out the measurements from the ebay listing and compared them to my pickup, no-go. The pickup is quite a bit wider. I did email the seller and got a reply back very quickly. This might not be the end of it.
1967 Impala 283 1974 '100' 258 |
Far as I know, steel Scout II tanks are available through the LL dealers. Don't know the cost, but it's a limited demand item so I'm sure they're not as cheap as a Jeep tank would be but they're still doable.
Dennis, keep me updated on what you find out. just thought I would chirp in. You can get a new scout radiator from 1-800-radiator for around $400-$500. As far as gas tanks go, why not up grade and get a plastic one from MTS? I have had two of them now and like them. won't rust.....bonus.
Why farm half when you can FARMALL! 73 scout II- "Agnus" 76 terra 77 trail scout (custom body) 79 GMC 3/4 ton (Dad's truck) "The General" 02 H.D. Sportster 883R |
I have one of the plastic gas tanks, actually I've had several in different vehicles, and my main complaint about them is getting the sending unit to not leak. The sending unit 'socket' for lack of a better word has to be screwed into the plastic tank, and with the thickness of the plastic tank you can't install the retaining ring like you do on a steel tank, or at least I've not had much luck doing it that way. The O ring gets cut or rolled and it leaks, and if you loosen up the screws to give enough room to get the sending unit in and then tighten the screws they tend to leak. I've got one in my 78 fiberglass Scout II, and I have to drop it because the sending unit isn't working. I think when I do, just to make sure, I'm going to cut a thick paper gasket the size of the 'socket' and cut the center hole out to fit the sender, then use that between the tank and 'socket'. I think if I run the screws down through the gasket material it should seal them off from seeping and solve the problem, but that's a 'quite a bit later' ordeal, I've got other things I have to do on my other Scout first.
Dennis,
that is a heck of a deal. Glad I asked ![]() JJ
1973 Travelall 4x4 1110 392 727 TF 1973 Wagonmaster 4x4 1210 392 727 TF 1974 Pickup 4x4 100 392 4 spd lifted 1975 Flatbed 4x4 200 392 4 spd 1976 Scout II Diesel 4spd Dana 300 1979 Scout II 345 727 TF Project (Mrs JJ's) Now we have SIX IH's and a State Farm Fleet Discount
I'm glad you asked too, I had forgotten about checking in with them!
OK, back to the top, I got the new radiator last night via FedEx. It's not installed yet, I have to wait for halfway warm weather, looks like maybe later this coming week will work. But I unpacked it and checked it out and took a couple of pics to show what it looks like. First impressions are that it looks well constructed; I've bought a couple of aftermarket replacement radiators off of Ebay for 'modern' vehicles, and they usually have plastic tanks, one large row of cooling, and the tanks and fittings are crimped and cemented to the core. This one is all TIG welded, and for an aluminum radiator it's pretty heavy, heavier than I expected. Looking in the bottom hose opening, the core has three rows just about the same as the copper/brass radiators do. Actually, everything I could see is a direct copy of the 'stock' Scout II radiator, but beefier since it's all TIG welded and the aluminum they used is thicker than the tank material on the stock radiator. The upper radiator hose connection isn't formed and curved like the stock copper/brass radiator since the aluminum is a lot thicker; it's two pieces mitered and welded to form the 90 degree angle. It has the captive nuts for the stock shroud and stock type mounts for mounting it. All in all I'm happy with it, if it installs like I suspect it will (just like stock) I'll post up then also. As far as cooling capacity, I'll probably have to wait on that since the Scout is about to get itself stripped and sanded for paint, and I won't get it back on the road until that's done. But I have no reason to think it won't cool just fine, at least as well as a stock radiator and for about half the price. I currently have a three row copper/brass radiator in the Scout and it's had issues keeping it cool at idle in summer with the AC running. I've tried a few different fans, but in the interest of 'apples to apples' I'll leave the fan alone when I swap over so that I'm comparing the exact same setup and can give results that aren't changed because I changed fans. Sorry it'll take so long for those results, I'm just happy that I'm going to get moving on the Scout at all!
| 1970 , 345 , aluminum , build , car , cost , d series , ebay , engine , hose , international , parts , pickup , project , racing , radiator , rusted , scout , scout ii , sii , transmission , travelall , truck , wanted , work |
| Axle Swapper Info by Wheeled Scout | orodos | BP IH Knowledge Wiki | 0 | 10-23-2011 05:54 PM |
| Scout II engine swap question. | mntgoat | General IH Tech | 30 | 01-31-2005 09:05 AM |
