how much weight does the engine stand need to hold.... suggestions.. thanks
With the fact that it rotates a few degrees and then goes clunk means there may be problems beyond a basic rebuild, like a broken rod.
Doing a full rebuild on a SV is expensive but then of course you'll be good for another 300K, used engines can be had for much less and if you can run a compression and oil pressure test on a hot engine you should know if you'll be good for another 100K. |
Sounds like you do have some major problems. Tear it down and then use the brains on this site to finish the job.
Rob Gimmel 68 800 3 spd trans 152 engine ![]() A man who has nothing which he cares about more than his personal safety is a miserable creature who has no chance of being free, unless made and kept so by the existance of better men than himself. John Stewart Mill |
Rebuilding an engine isn't hard. For the most parts it's taking stuff apart and then putting it back together again. Stock rebuilds are the easiest.
The hard part is two fold. The first is determining what needs to be replaced and what can be reused. This involves lots of measuring with micrometers and such. The second is putting it back together and getting your ring gaps correct and your bearing clearances right. It's easy enough to do you just have to take your time. As far as heads go, send them out to a good machine shop if they need work. Since your engine was running hot at the very least they should be checked for warpage and cracks. Take your time, keep things organized and questions or read instead of assuming and you'll be fine.
IHSTO Club President, please feel free to contact me with questions and comments. CoD - Prodigal Son Last edited by Carl Wiese; 02-29-2012 at 10:22 PM. |
thanks for the words of encouragement ... i feel much better than i did earlier... as said before i am waiting on the manual.... i will do my homework.... it is a lot easier knowing that you all are here to help
when i do in fact get to that point ..and i will ... i will start a new thread with pictures and everything... i know how everyone loves the pics |
David Dixon '80 Scout Diesel - Somewhat modified , currently resting, awaiting a new windshield and new body panels (Like, most all of 'em.)'78 Traveler, 345, auto, totally stock. |
Matt, I have an engine pulled from a running truck (six months ago) and stored inside that you can have. I would like to keep starter, dist, and accesories. Basically you can have the short block for the price of driving to Colorado Springs. It is either a 304 or 345, if you are interested let me know.
Mike Scherr '75 Scout II, body by sawzall and Lincoln '75 Scout, step-scout, Anybody need a Scout? '76 Terra, where do these things come from? |
WOW... unexpected... yes .. interested.... wow.... so many questions and options are flying thru my head....how interchangable are the components if it is a 304.... would i just take off what i need and add to yours..... wow.....
| adapter , broke , cap , compression , engine , fluid , hot , machine shop , manual , oil , overheating , parts , pictures , power , pump , radiator , rebuild , scout , shop , start , test , truck , water , water pump , work |
| IAC vs Coolant actual settings | Darrell Tuxworth | Injection Tech | 14 | 12-16-2010 05:21 PM |
| Most common Bonehead mistakes on your first IH engine rebuild | Rusty Scout | General IH Tech | 0 | 08-18-2010 11:08 PM |
| Engine Rebuild Gurus-this One's For You! Share Your Knowledge Please. | BeachBinder | General IH Tech | 76 | 08-15-2005 09:38 AM |
| Re: Engine rebuild advice needed, 17-17-04 | Mernjohn | General IH Tech | 4 | 09-22-2004 02:21 PM |
| Engine rebuild advice needed | Mernjohn | General IH Tech | 10 | 07-18-2004 02:19 PM |
