#31
#32
I found a drag link on Ebay that is a GM part and perfect length for a cross-over connection. $15+$8 shipping.
#33
sounds good.I take it you will try and rotate the pitman arm by 90' to go with a crossover drag link?Or are you going to use a 2wd GM box?What front axle are you using?Are you going with a high-steer setup,or using a different tie rod to connect the crossover steering?
#34
Well, I have been dinking around with this and not getting anything done. I finally found the correct steering gearbox after letting two good ones get away. I ended up buying a fully rebuilt unit that cost three times what I'd thought were too expensive used ones.
I am not going top steering because this is an old Dana 44 with the rectangular four bolt pattern on the knuckle bearing cap(closed knuckle). I might be able to fabricate something, but I will just tie the drag link to the original steering rod. I have done this before by welding a boss onto the linkage and reaming it to fit the rod end on the drag link. The only draw back on my drag link is that it is the style that is not adjustable the the rod ends are permanent type. Can't be replaced and I don't think they have zirks for replenishing the grease. Gear box gets here tomorrow. Also the fittings for the pump lines are all flair type, making the pump and lines compatible. The old lines that came with the pump show no cracks when I flex them. I may have to install new, but these look good enough to see it everything works when the installation is finished. |
#35
build update:here some pics of the cab re-construction,no longer a flintstone mobile.
#36
Great Job!
![]() It's not easy to make all the parts fit nice and tight like a jig saw puzzle. You did great!
#37
still a few patches left to so on the back of the cab. |
#38
build update:cab all fixed up and back on the frame.Steering column and hydroboost brake system install underway.Sonny boy had to testfit the swampers to make sure they will fit
.Looks like no problem.
#39
Nice build! It's good to see some pickup builds. That's why I'm here (I've got 2 to do). I'm curious how well that dom 16 stuff works. I was thinking about using por 15 on my frame so half the cost would be nice.
Keep up the good work!
#40
that DOM16 seems real good,dries to a rock hard glossy finish,whereas the POR15 we used was more of a matte finish.
Just finishing up the brake system right now,more pics soon. |
| 110 , 1100b , box , brake , build , canada , chevy , clutch , conversion , crossmember , cylinder , diesel , engine , lights , master , mounts , parts , pics , power , project , shackle , starting , steering , tranny , truck |
| Mini Builds-Ups! | Damian Grihalva | D and C Extreme | 10 | 01-25-2012 09:38 PM |
| What Does What? A build for everyday IHers! | Damian Grihalva | D and C Extreme | 57 | 01-10-2012 08:12 PM |
| My 67 1100B Build... Lots of pics! | AzTravelall | Binder Builds | 27 | 10-04-2011 08:36 PM |
| Want to build propane (only) 345: | Monkeyplasm | General IH Tech | 46 | 12-08-2008 01:10 PM |
