Don't get me wrong, my son Tyler is a good kid, but a teenage boy is a teenage boy. Me and my kids spend alot of time in the water. Salt water and fresh. We surf, fish, kayak etc. I want to be able to build this one to get us to the backwoods places at the river and lakes as well as get us to the ocean and do some surf fishing. Since Tyler will be doing some of the driving, Auto trans was important. (less pedals the better) So here is what I picked up from another SEBA member. 1972 Scout II, 304, 727 auto trans, D20 t-case, 44 in the rear with 3.73 gears, 30 up front. No power steering, drum brakes. ![]() ![]() ![]() ![]() It has a fairly straight body with limited dents and very little rust on the body panels. The tailgate has a few dents and the driver door but not to bad. Interior body is also pretty solid. except a few spots that will have to be cut out and patched. ![]()
Mike 1965 Scout 80, 345, SOA, full cage, (sold) 80 Build 1972 Scout II in progress 1967 Travelall panel I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson |
Now here is some of the bad spots. first this panel will be replaced.
![]() And around the wheel well will have to be fixed. ![]() This is the worst spot. The rust has not extended to the braces but the floor pan has to go.
I also got another 727 with it when I picked it up. It is supposed to be a rebuilt trans.
![]() And the famous box of parts that comes with every Scout you buy. Most of the trim items are in there as well as a bunch of other stuff. ![]() Extra fuel tank and interior top pieces etc. I have had to turn my old Chicken coop into a parts storage area. ![]() ![]()
On to the engine.
Engine moves freely but carb was spewing gas when I hooked it to an electric fuel pump. So I took it off. It was a Holley 2 brl. I will be changing to a Autolite (motorcraft) 2100. Mainly because I have rebuilt a few of the 2100's and they are simple to rebuild and easy to find. Plus they are very reliable carbs. (remember teenager). ![]() I still chuckle when I see this sticker. Do not drain, permanent antifreeze. ![]() ![]() The bad news on the engine is After I took the valve covers off, they were dry and rusty. I am really hoping the oil pump is not bad but it doesn't look like oil has made it up here in my lifetime. I will be using a drill and try to see if I can bring some oil up today. ![]()
BTW, I'm pretty sure this is not the original engine. Plus I dont think 727 came in these until 73. Let me know if I'm wrong on this.
Here is my progress for the weekend. I took most of the front end off, at least down to the inner fenders.
![]() Not any rust to speak of so I'm pretty happy with that. ![]() ![]() ![]() Nice and clean inside. ![]() ![]() Also I found another sticker under the grime. ![]() Another plus for the day was that I primed the oil pump and finnaly got oil to the top. It took 2 batteries in the drill and alot of turning the engine but oil finnaly showed up. I also replaced the distributor with a new one and I am now getting spark. So as soon as I get the carb I should be good. I hope.
Alright Mike! Glad to see you're making some headway. Looks like you have a pretty good base to build on.
Andy Gilliam SouthEast Binders Association 75 Scout II. 345, 727, 4"SUA, 34" LTB Cub Cadet 129 Both currently non-op. |
Good to see you with another IH project. I'm sure Tyler will love it.
![]() Looks like a pretty solid Scout. A few areas that need some love but not too bad. That engine is looking a little sketchy though. It looks like it's been sitting with the hood up and the valve covers off of it. It may be worthwhile to look a little deeper before you exert a whole lot of energy into it. I would pull a compression test at minimal.
67 800 Limited GRC Edition, 266/T-19W/D300 79 Terra Rallye, mostly stock driver 61 Travelette, KOH Chase inspired build...........one day! 1250 Cub Quietline |
Yeah, I agree with you Gary, I will do a compression test this week and see what happens. If it does not go well I will be looking for a running SV.
When I bought it. I bought it mainly because it had a solid base to start with and an 727. I didn't have any promises on the engine so if it doesn't work I'll swap in another, If it does it will just be a plus 1.
Well I did a compression test today. Here is what I came up with.
All cyl were int the area of 120-130 except #5. It was only sitting at 60. Now this was with a cold engine that hasn't ran in who knows how long, but I'm thinking stuck valve. Any opinions on which way to proceed?
| 304 , 72 scout , 727 , 800 , auto trans , body , body panels , build , case , column , door , engine , front , gears , panel , panels , parts , project , rear , rust , scout , scout ii , seba , steering , water |
| My 69' Scout 800 Project | db1115 | Binder Builds | 1443 | 06-15-2013 10:20 AM |
