Go Back   Binder Planet Forums > IH Clubs > Member-Club Forums > Sonora Desert Scouts (Arizona)
  #41
Old 03-23-2012, 10:10 AM
Lowell Lowell is offline
Send a message via AIM to Lowell
Default Re: Where did you drive your IHC today?
Originally Posted by az scout guy View Post
Not Junk, just swap the whole axle into your 800
How hard would that be to put on an Scout 80? What is the gear ratio? My son and I are thinking about starting on the 63.
Lowell
62 scout 80, 75 Scout II
Sonora Desert Scout member
  #42
Old 03-23-2012, 10:32 AM
az scout guy's Avatar
az scout guy az scout guy is offline
Change the spring mounts on the frame to Scout II width...the axle is a few inches wider than stock 80.
http://canyonoffroad.com/
76 Traveler
SOA
RS
High steer
Chevy 350 TBI
700r4
Dana 300 with 4 to 1
Dana 44's with OX locks
Chromoly axles front and rear
37x12.5x15 MTR's
Eaton Beadlocks
A/C
Autometers
Daily driver
  #43
Old 03-23-2012, 10:33 AM
Rollin' 6 deep to the Rendezvous
76 Traveler
SOA
RS
High steer
Chevy 350 TBI
700r4
37x12.5x15 MTR's
Eaton Beadlocks
A/C
Autometers
Daily driver
  #44
Old 03-23-2012, 10:38 AM
AZDIESEL's Avatar
AZDIESEL AZDIESEL is offline
I'll smoke you a deal on it Lowell. I'm not going to use it. Ill look and see what ratio it has.
Freakin awesome man. An IH convoy!
IH JUNKI
SOAZ BINDERS
"You can be a Boy Scout or a numb nut"....- Ted Nugent
"Only a vertuous people are capable of freedom. As nations become corrupt and vicious, they have more need of masters." -Benjamin Franklin
  #45
Old 03-23-2012, 11:31 AM
PM sent.
Lowell
  #46
Old 03-23-2012, 11:38 AM
mcsmythe's Avatar
mcsmythe mcsmythe is offline
take lots of pics.
1961 Scout 80 half-cab: 152ci; Weber DGV; Pertronix; 3spd T90, twinstick Spicer 18; PTO with Ramsey #8000 winch; Front Dana 27; Rear Dana 44 w/PowerLok; and.............. multiple gun racks.
http://www.binderplanet.com/photopos...-29-12_825.jpg
  #47
Old 03-25-2012, 03:42 PM
steve graham steve graham is offline
Back into the garage.
Had the trailer hooked up the Scout ready to head out to the rendezvous. Saw leak coming from the front left of the engine.
The throttle shaft seal on the injection pump was gushing Diesel fuel. A minor fix but not able to fix it in an hour. Scout stayed home.
1980 Scout Diesel, Cummins 4BTA Powered, 92 Dodge CAC, NV4500, 3.73 gears, Atlas 4.33, rolling on 33/10.50 BFG muds, modified H1C, Cold Air Intake
  #48
Old 03-25-2012, 08:54 PM
timscout1's Avatar
timscout1 timscout1 is offline
All the way to Rendezvous and home, "TUG" never missed a beat. See you all next year!
choose IH and fly with quality under your belt.
73 1210 4x4 Travelette 5 spd. 392
300 utility tractor
64 Scout 80-152/ weber 32/36
1955 IH RC180 cabover 7.3L
1947 IH fire engine GD233
1970 Fleetstar 2010 fire engine LV549
73 Scout2, 304.4 spd.
Member, Sonora Desert Scouts
  #49
Old 03-25-2012, 08:59 PM
76 xlc 76 xlc is offline
Banned
Glad you had a smooth trip home.
I made one trip down the hill, up a little rise, and down across a wash. Then I came to a stop. Heading into the valley, I went over the river then turned to the north and up a series of small rises.
Next, I turned due south, then drove to the west in big circle around a hill, and I was at AZIHR 2012. Later, I returned home, but that's a whole 'nuther story...
Hope all had fun!
  #50
Old 03-27-2012, 09:05 AM
mcsmythe's Avatar
took my daughter for her first ride in the Scout. Only went around the neighborhood but needless to say she was totally thrilled and the smile on her face was incredible.
2300 , bronco , cam , carb , carb. , engine , front , fun , gear , holley 2300 , hot , ihc , kit , liftgate , lockers , paint , rear , rebuild , reverse , scout , scout 80 , springs , stalling , top , worth
Starter Shim / Shorter Drive Gear usugarbage General IH Tech 11 05-21-2010 09:20 PM
Front drive shaft jayrod0 General IH Tech 1 05-19-2007 09:19 AM
2wd74 scout II R hand drive convert to 4x4 diesel Dieselproject Diesel Tech 9 09-13-2006 09:34 AM
2wd74 scout II R hand drive convert to 4x4 diesel Dieselproject The Skunkwerks 14 09-12-2006 03:29 PM
cv drive shaft problems scooter-b1 General IH Tech 5 10-21-2002 10:02 PM
