Old 02-07-2012, 02:46 AM
K-Dirt K-Dirt is offline
Default Np201
I have a 66 1100A pickup with a noisy NP201 transfer case. I am told internal parts for these are hard or impossible to find.
Is there someone who rebuilds these?
Has anyone done a swap to a NP205? Apparently there are parts for those?
Is there some other swap or repair solution?
Old 02-07-2012, 05:05 AM
Default Re: Np201
Are you sure its a 201,most should be a 202.A 205 out of a newer IH will bolt in,have to do a little changing on the shifter.
Old 02-07-2012, 12:48 PM
Default Re: Np201, Really a np202
You're right, it is a New Process 202. Any parts available? Any rebuilders out there? Upgradable to a divorced 205?
Thanks
Old 02-07-2012, 03:55 PM
briankk's Avatar
briankk briankk is offline
Send a message via Skype™ to briankk
Default Re: Np201
http://cobratransmission.blogspot.co...ase-parts.html
Old 02-07-2012, 04:06 PM
ian choplin's Avatar
ian choplin ian choplin is offline
Default Re: Np201
Have tried Lester's Gear or Harmon 4WD? They are both pretty knowledgable.
And they're both in Tulsa.
Ian
'80 Scout II TBI 345, 727, 2.72's,h-boost brakes
'73 1110 Travelall 4wd, TBI 345, ps,pb,a/c
'78 Fiat Spider (1.8L w/ TBI!)
Cub Cadets 149, 100, & 125
Old 02-07-2012, 05:03 PM
john breeze john breeze is offline
Default Re: Np201
the 202 as the same gear ratio as the 205
Old 02-08-2012, 04:04 AM
Default Re: Np201
Thanks very much. For the record, Lester Gear Said "No IH, Ford and Chevy Only, If it's IH, we don't want to see it."
Harmon was very helpful.
Old 02-08-2012, 09:27 AM
Default Re: Np201
That's too bad about Lester's. Last time I delt with them was for tranny parts to rebuild a 727 Torqueflight. But I suppose that isn't a strictly IH application.
There is a junkyard in Sperry that, at one time, had several 4wd IH trucks. Don't know the status of those trucks now though.
Ian
Old 02-08-2012, 09:30 AM
Default Re: Np201
Just a thought, have you tried Blumenthal's in OKC? They built a t-case for a 3/4 Dodge for me a couple years ago.
Ian
Old 02-08-2012, 09:58 AM
Default Re: Np201
the 202 is generic transfercase they did put them in old ford's. the 202's are tougher than the 205's. gears are thicker in the 202.
200 , 727 , bearings , brake , broke , bus , case , chevy , drum , find , ford , front , gear , gears , hose , military , part , parts , problem , racing , rebuild , tranny , transfer case , turbo , vibration
PTO for NP200, NP201, NP202 Colin Rush Restoration Purists 6 10-23-2010 11:37 AM
need to find a rebuild kit for my np 201 gsxrrider27 Restoration Purists 3 04-12-2010 06:47 PM
