here we go again.
Funny, that's the same thing I thought even before I began typing last night. The strike over is a nice touch, but you placed it over the wrong post. Here, let me show you what you should have done:
There now. So much easier to digest minus the superfluous and non-pertinent drivel.
Children,children. Let's get some more info on what was going on when this trouble evidenced itself. As this appears to be happening in Texas, and as we don't know at what time of year it was misbehaving, how about getting some history on this thing? Weather has something to do with it, I'm pretty sure.
Ok, just so all know. I bought this from someone in Texas who had it about a year to putz around a lake. This guy also has a home in AZ and that's where he bought the Scout. The person he bought it from did all the rebuilding. There was no knowledge transfer between the 2 people on what was done. However when I bought it the PO provided a couple of boxes of original equipment that had been replaced. However a carb was not among them so I'm not sure if it is the original carb or not. I left it at my mechanics place yesterday to see what he can find as well as swapping out the fuel pump. So I can't take a picture for now.
Now on the symptoms again. My other truck was broke down so I took the Scout to work for 3 straight days. Every day was similar temp but the 1st day was probably the warmest in the mid 60s. The trip each way is 17 miles with about 12 miles on interstate. So day one to work, no problems. Day one trip home and I have problems when I exit the hwy. I limp it home and the next 2 days I have no issues. Similarly this summer I took it on long hwy drives multiple times. Summer temps at 100 or so. These jaunts were 70-100 miles on the hwy before slowing down. About 1/5 of the time I would have problems. It's so irritating when it happens because it takes several minutes to restart and then it still is herky jerky for a while. I'll report back when I get it back from the shop. Supposedly they hired a mechanic who understands old vehicles. We'll see. I did a vacuum leak check with the only equipment I have (my hands), by removing the air cleaner and covering the intake with my hand to see if it died immediately or tried to keep running.
1967 800 1964 706 1942 Speedex 1964 Ford 4000 |
Thank you for the supplemental. Too bad pics aren't a possibility. Intermittent issues are usually the most vexing to diagnose and repair. Successful cyber-diagnosis almost always depends on knowing what specific components are in play. Without that basic data, about all anyone can do is lob spitballs at the situation. Perhaps a lucky few hit the mark, but most will not.
Since the trouble seems to happen with relatively warm temps, I ask whether the gasket between the carb and the intake manifold is the type that acts as a heat sink to lower the heat transfer to the carb. If you're doing high speed driving on freeways the heat can build without realizing it, so it seems the problem is vapour lock. Start there.
---I throw out as many possibilities as I can think of, cause I don't know when I'll be around, and what little bandwidth it takes to type is better than people waiting for answers to "what do I check next?". I can also remember most of what I've learned & have the ability to think on my own. Now that I am through with the introduction, may I offer my apologies, taltyman if it is ever overwhelming... relevance comes with understanding and deciding what's applicable from the possibilities is up to you* as the one who inquired.
---If original, your carb should be a 1710... which rarely survived the journey to this day & age due to abuse by DIYers. Whatever you do, don't let anyone talk you into sending that in to be "refreshed" or as a core. That carb will prove to be invaluable and no matter what kit for older (non-44) 2300s you purchase to rebuild it, there's no "special" parts/gaskets that you will be seeking other than the Base Plate Gasket I mentioned in my first reply. You can rebuild it yourself with little common sense and good instruction and you stand no chance of being ripped off. ---Here's where you will find key info on a 2300/modular carb. (Clickity-click for larger image) ![]() ---In the OEM world, there will be a List#, an OEM P/N & a Date Code. List# will say "List" xxxx(± -xxx-xxx) OEM P/N will be xxxxxx-xxx and date code would be xxx or xxxx. ---If you decide rebuilding of the carb is necessary, please do not be discouraged from asking what parts besides the actual kit should be used. We are in an era where ethanol gasoline damages components and while Holley isn't 100% alcohol-approved with their parts, some are and other companies do have parts that they don't yet make. You will be tossing the greater portion of any 2300 kit to the side and ordering special parts to complete the rebuild if you want the rebuild to last without issue. Some parts can be found here in the beginning of my entry to the Useful Part Number List thread. Just search for the keyword Alcohol (as well as Reusable) in that post (and ignore the 0.150" [Needle & Seat] Fuel Inlet Needle). The list of alcohol-rated parts I have had since 1999/2000 when I began the change-over on my system. A lot of those parts can be ordered from reputable ebay sellers at a fraction of what the big names want and some of t hose sellers even have their own performance shops you can order from as well. I'd like to think that in ten more years Holley will catch up, but they have a lot of governmental pressure as well as supply/demand to think of, so I don't hold my breath. Gotta fend for yourself. ---Let us know what List# and I'm sure we can give you a P/N for a rebuild kit as well as list of "special" parts. If the mechanic has already begun and that request is too late, no biggie. Maybe he will be wise enough to stamp the Main Body Gasket out of something like Buna!!! Doing that, you will never need to buy another kit, just stamp a few gaskets in case one tears while rebuilding and buy a new Needle & Seat, alcohol-approved Power Valve & Accelerator Pump Diaphragm. ---Don't want to spend the extra money? Consider: If the parts in the carb like the Power Valve match OEM, they won't be in a kit. That should be a 4.5-6.0 and the kit will come with a 7.5. You have to buy the correct ones anyway, so paying $3-$7 more for each alcohol approved makes sense. The Needle & Seat should be a 0.097" for the 266/304 and the kit will come with a 0.110", so you'll want to buy a matching there as well. The Fuel Float if not brass won't live much longer, so $4.99 for that is also logical. The carb will have to have the Fuel Bowl dropped at least* every 2 years to clean out debris, so reusable Metering Plate & Bowl Gaskets are wise... unless you want to buy another* $30+ kit just for those two gaskets. Rebuild for 1-2 years or rebuild for 5+ years. Your* choice. ---All removable parts will have part numbers stamped into them too, so don't just discard your old stuff and use the new trusting the kit's contents. Throw away that info and you'll be needing the correct* (pretty much era specific due to amendments) print of the Holley Ill. & Specs manual or someone who "doesn't know" to relay the info when it's too late; If they're not pushing up daisies... lol. ---Vapor lock, float/fuel level & condensation due to change in temps are excellent suggestions as well.
I would can the diaphram fuel pump, and go with an electric inline and fuel regulator - all at Autozone for like $30.00...
| 100 , 266 , 800 , carb , carb. , engine , fuel , fuel pump , gas , gas pedal , hot , idle , parts , pedal , problem , pump , rebuild , replacement , scout , scout 80 , scout 800 , stalls , starting , vacuum , vacuum lines |
| Gas Pedal Issues 1975 150 Pickup | Rusty Scout | General IH Tech | 1 | 05-26-2009 08:29 PM |
| 800A gas pedal ball studs broken - now what? | Mark B 70SR2 | General IH Tech | 17 | 02-04-2008 08:08 PM |
| pesky drip from my sd33t injection pump | kevin hueser | Diesel Tech | 28 | 10-12-2005 11:12 PM |
| gas tank hoses and gasket, electric fuel pump, etc. (kind of long) | kevin1 | General IH Tech | 5 | 07-01-2004 09:04 PM |
| Gas pedal hard to push, any way to adjust it? | Dave_STL | General IH Tech | 20 | 03-26-2003 05:20 PM |
