Go Back   Binder Planet Forums > IH Clubs > Member-Club Forums > Southeast Binders Association
Old 01-18-2012, 06:31 PM
SSIIbuild's Avatar
SSIIbuild SSIIbuild is offline
Default Re: The Saga Continues
Originally Posted by onetonscout View Post
That's an awesome build, I think I need one but then again I think I need every thing.
Funny I think I need everything as well. Now if I could just stop myself from trying to get one of everything.
I have way to many. And it's never enough.
Old 01-22-2012, 05:04 AM
michigandon's Avatar
michigandon michigandon is offline
I NEED that boom truck at my place for a weekend!
You guys are giving me the inspiration I need to get my butt in gear.
Old 01-22-2012, 08:04 PM
jhnyct's Avatar
jhnyct jhnyct is offline
The "plan" for the suspension is laid out. Randy is waiting on a few fab pieces and some suspension bushings. Its all over but doing it now. Once the suspension is squared away, then its on to setting the drivetrain. Mounts and crossmembers. Good times.
Jason Honeycutt
1978 IH Scout II EFI
1978 IH Terra trail rig
G R C built
S E B A
www.youtube.com/jhnyct
Old 01-30-2012, 10:01 PM
SSIIbuild's Avatar
Speaking of suspension.
We decided to go with the springs from the Dodge as they happened to be almost new lift springs, and would put it at about the height I am after. We also figured they ought to be able to support the weight of the Cummins since they were made for it. So I had to order some new spring hangers and shackles to accomplish this. Thanks to Barnes4wd they arrived in no time. But since the stock bumper mounts are attached to the spring hangers. (or I should say were, as the PO was kind enough to cut off of mine) And cause I wouldn't mind having a bumper. Some lines were drawn.
Some rough in shots attached to the spring hangers
After some prep
Old 01-31-2012, 08:15 AM
raleighrugger's Avatar
raleighrugger raleighrugger is offline
Dang Jamie, it seems like your builds move at light speed compared to mine! Almost 2 years on the 200 to get her in a driving state, and I don't even want to talk about my poor SII that's in a million, scattered pieces going on almost 3 years later....
That Travelette is going to be SICK! If you want some nifty bulkhead connectors, for when GRC does the wiring, let me know. They'd look good on the firewall next to that 6BT.
1975 Scout II
304V8/T-90/D-20/D44's-4.09's/SOA/35's
1975 200 4x4
345V8/TF727/NP-205/D44 & D60
"To be the Man, you must beat the Man"
Old 01-31-2012, 08:55 AM
SSIIbuild's Avatar
Well I'll definitely take all the credit for how fast my builds go. If I were working on them they would never get done. That and the quality that GRC puts out are the reasons I have given up doing things myself.
I'll talk to the GRC about the connectors and see if they have a plan in place already.
Don't worry I still have some trucks in many pieces.
Old 02-05-2012, 03:40 PM
SSIIbuild's Avatar
Time for a little update. I initially received this image via text message without a description. So other than a good start for an Xwing fighter what could it be?
Old 02-05-2012, 03:43 PM
mormetl's Avatar
mormetl mormetl is offline
Removable double cup holder?
'77 Terra - Propaned 196 w/T-19 Wide,d20, 5.13's, SOA & 36 Iroks - "Roadkill" - FOR SALE
Fab work courtesy of GRC
You just gotta keep livin' - L-I-V-I-N
Owner of Triple Diamond Transport Inc.
www.triplediamondtransport.com
Old 02-05-2012, 03:45 PM
SSIIbuild's Avatar
That's it. I knew they took strength seriously down there, but I didn't know that seriously.
Okay so maybe that isn't strong enough to be a cup holder so we'll have to use it as an engine mount crossmember. At least a removable section of it, so the oil pan can still be dropped without much hassle.
Old 02-27-2012, 06:32 AM
Scottiebell's Avatar
Scottiebell Scottiebell is offline
Did you purchase this truck from Tommy, in Rio Rancho? Friend of mine. I lived right around the corner. Beautiful rig, and looks like its only getting better. Cant wait to see the end result.
Barbie Called, She said she'd like her JEEP back!
1975 Scout II XLC
345 TF 727, Dana 20
Dana 44's W/ 3:54's
Spartan Lockers Front and Rear
4" Rough Country
33" BFG A/T
2wd , 4x4 , axle , body , build , build thread , clean , cummins , diesel , engine , find , firewall , frame , front , ground , led , oil , part , parts , project , rear axle , shop , start , travelette , truck
Navistar Continues on Profitable Path Despite Tough Market Conditions Jeff Bade Navistar News 0 06-09-2010 04:10 AM
And the Brake Saga Continues!! - Hydravac Mark Ashford Triple Diamond Trucks 10 08-10-2006 01:00 PM
Rebuilding Scout II PS Boxes, the saga continues... Chrispucci IH Scouts & Trucks of Oregon 12 07-24-2006 03:16 PM
Loadstar Saga continues Basil Gunther General IH Tech 3 05-27-2006 12:26 PM
DANA 60 axle #'s. The Saga continues! ALEE@CSIUSA.WS General IH Tech 0 12-20-2002 05:17 AM
