The BTA5.9 (early '98 12-valve, 215hp/440 lbs./ft.) in my pickup is only getting is only getting a reliable 18mpg., both city and highway. Does anyone know if there is common "tune-up type" cause for this particular engine getting such crappy MPG--i.e., injector rebuild, valve lash too wide, etc.? Or a website where I can ask stoopid questions? Eddie |
What tranny u got in that rig? If its a slushbox I'd be looking that direction... seems to be the weak link with the Chrysler products.
68 1100C 4x4 T-All http://www.binderplanet.com/forums/s...d.php?t=105580 79 Scout II 345/4spd Charlie Sheen 80 Traveller SD33T http://www.binderplanet.com/forums/s...ad.php?t=89172 96 F-250 Powerstroke Big Red |
The Dodges I've heard of that got good mpg were running tranys with OD and axle ratios of 3.54 or less with 31" to 32" dia tires ie 235/85/R16 or 265/75/R16.
Tranny--.73 OD
R/A------3.07 Tires-----31x10.50/15 Eddie |
Check for leaks in your air-to-air plumbing first then check your injectors and adjust the valves.
Yea, yer mileage sucks. I got 20 in the pos Dog-de I had. O/D, 3.54 on slick 33's.
Oilburners.net or com, I forget which is one place to look and another cummins only site that I haven't found since my last computer crash are good places to look
1972 Scout II |
How much boost are you getting?, EGT's? When's the last time you changed air filter?, fuel filter?
1980 Scout Diesel, Cummins 4BTA Powered, 92 Dodge CAC, NV4500, 3.73 gears, Atlas 4.33, rolling on 33/10.50 BFG muds, modified H1C, Cold Air Intake |
A lot of 31x10.50/15 are much less than 31" more like 29".
Another question is how much do you like the skinny pedal?
15" tires on a 3/4 diesel P/U?Did not realize Dodge made a 15" 8 lug
It's a replant in a F150
1972 Scout II |
| 265 , air , air filter , axle , chrysler , cummins , diesel , dog , engine , filter , fuel , fuel filter , pickup , question , rebuild , scout , size , sucks , tire , tires , tranny , valve , website , wide |
| cummins or power stroke in 1200 | eluke13 | The Skunkwerks | 9 | 02-21-2007 09:20 PM |
| A very silly question...Try not to laugh? | cjlarsen05 | General IH Tech | 8 | 01-11-2007 02:07 PM |
| Tires/Gears/Power/Drive Quality, mpg, anyone...?? | ISDE rider | General IH Tech | 0 | 03-22-2004 01:46 AM |
| 304 question. what mpg is normal? I am getting 10 and it feels sluggish. | ra6991 | General IH Tech | 2 | 11-11-2003 11:14 AM |
| Off topic - Cummins L-10 fuel valve question | Russ McLean | Diesel Tech | 7 | 09-02-2003 10:12 PM |
