  #91
Old 07-14-2012, 04:26 PM
jmait769's Avatar
jmait769 jmait769 is offline
Default Re: Father/Daughter Build '65 Scout 80!
Originally Posted by Albuq. Henry View Post
The scout is looking way good! I wish I had your patience and could focus on so much little details.
Tell the guy if he isnt gonna sell, he needs to at least drive it
Thanks Henry! Yes, kind of sad seeing it like that!
Got a box in from IH Only North yesterday and part of the order was some Rough Country shocks. I knew these would be much bigger than the stock shocks but they would not bolt up. They would hit the steering stop on the axle and I could not attach at the upper mount.
They would also hit the steering arm on the knuckle when turned into the steering stop.
At first I thought I would have to return them after searching for a fix and not finding anything that did not require fabricating new mounts. But then I realized I might be able to remove the large spacer (arrow) from the mount and mount the shock closer to the frame with washers.
On top I used two thick washers and on the bottom I used one. I had to use two on top to keep the shock from hitting the frame where the boot attaches.
This allowed about a 1/4” space between the shock and the steering stop on the axle.
It also allowed plenty of room between steering arm and the shock.
Anyone see any problem with this? It does not have full weight of the scout on it but I put a bottle jack between the axle and frame and flexed it some and I did not see any issues.
Thanks!
Jay
  #92
Old 07-14-2012, 05:07 PM
Comanche Scott's Avatar
Looks like a good resolution to me.
From the pictures, it appears you have the shock mounted in a straight line, so there should be no side loading.
No side loading, no stiction, no harnshness.
Scott
  #93
Old 07-14-2012, 06:30 PM
oldblue72 oldblue72 is offline
Great build! I've been following this one with interest. I am in the process of fixing up my 1967 800. You'd have to check with the shock manufacturer, but some shocks will operate just fine in the upside down position. That might give you a lot more clearance. Keep up the good work. Can't wait to see this one completed!
  #94
Old 07-17-2012, 08:17 PM
jmait769's Avatar
Scott
Thanks Scott!!
Thanks! That was going to be my first question to Jeff on the fitment of these but looks like they will work now. You should start a build thread!!
Some pics from tonight and you can see the shocks installed. At first they looked huge to me but now I think it looks ok. Jeff from IH Only North was able to track down the red shifter ball in the correct color and size we wanted so got those installed and painted the shifter levers to match.
Big news is that the garage order was placed today! I was able to go a little bit larger and stay within the budget. It came in at 22’ wide x 30’ long with 12’ walls. I have been stuck on garagejournal.com for the last few days looking for ideas so very excited. I guess I should start a build thread over there but I hesitate as the better half is always on me about my internet time! Lots to do so this build may slow down a bit!
Jay
  #95
Old 07-17-2012, 08:20 PM
jmait769's Avatar
Scott
Thanks Scott!!
Jay
  #96
jmait769's Avatar
Scott
Thanks Scott!!
Big news is that the garage order was placed today! I was able to go a little bit larger and stay within the budget. It came in at 22’ wide x 30’ long with 12’ walls. I have been stuck on garagejournal for the last few days looking for ideas so very excited. I guess I should start a build thread over there but I hesitate as the better half is always on me about my internet time! Lots to do so this build may slow down a bit!
Jay
  #97
Old 07-17-2012, 09:31 PM
Sweet! Bigger is always better, when it comes to shop space!
The shocks look like they line up perfectly. Very nice!
Is this a "Red Carpet" version?
In any case, I like the idea of the red shift balls. Pretty
Scott
  #98
Old 07-18-2012, 06:25 AM
jmait769's Avatar
Scott
Yes, Red Carpet “faux”!! We just like the look of the red on white kind of like this (Our dream mustang!!):
Jay
  #99
Old 07-18-2012, 07:11 AM
Scott
and then you find out," it's not big enough!"
  #100
Old 07-18-2012, 06:50 PM
AndyJ AndyJ is offline
Another great build, i saw that you guys are still looking for scouts. Do you check out copart at all?
http://www.copart.com/c2/onSaleResul...SEARCH_RESULTS
If that link does not work for whatever reason, there is a '74 Scout at a salvage auction in Abq.
1988 Grand Wagoneer
1992 Volvo 240
4x4 , 800 , axles , brakes , build , build thread , clutch , engine , frame , fun , main bearing , power , problem , rear , repair , rust , scout , scout 80 , springs , ssii , start , transmission , wanted , water , wiring
Online store Updated with More Products Jeff Ismail IH Parts America 1 11-25-2009 09:39 AM
Scout 80 Build Tres03 Hill Country Binders - Central TX 11 06-11-2009 11:46 AM
80/800 Serial Numbers Will Marsh BP IH Knowledge Wiki 0 02-01-2009 09:42 PM
1985 CJ Leaf Springs on Scout 80? Finder-Binder General IH Tech 1 07-11-2003 11:06 AM
