![]() First pic shows my radiator with mtg flanges on the engine side. Second pic shows my radiator lower hose connection which comes straight out. Third pic shows Mystery Radiator with mtg flanges on the opposite side. Fourth Pic shows angled lower hose connection on Mystery Radiator. Fifth shows P/N on Mystery Radiator, #385485 C2. Can anyone help identify application? ![]() ![]() ![]() Thanks in advance;
1977 Scout II, 304, 727, DANA 44/44/20, "BUSTER" 1960 Travelall, 4X4, 3/4 ton, "WILBUR" ![]() Sully |
---International 1310/Grunman Motorhome is what I have found. If it has the same dimensions as a Scout II's, I don't see why it couldn't be used, mounted to the front of the Radiator Support, especially in the case where a 345's thermo clutch fan is way too close to the radiator for comfort. If the same, the only thing I see is the need for a small flap/splash guard, made of ABS or fiberglass for the top & bottom to cover openings that would be created between the radiator and fan shroud.
i just found;D-model's 1000 thru 1300's w/ac-Auto-part # 385485-C1...t'all's & p'up's...jeff(all V-8's)
385485C2 was in my 69 1100 D series.
Do you want to sell it?
Thanks for the help guys. I will not be adapting it to my SII as my re-cored radiator was easily repaired and in really good shape. No plans to sell just yet as my local IH brothers already had dibs when I bought it and I'm not yet sure what my next Binder will be. If anything changes I'll let you know Jeff.
| 100 , 1000 , 1300 , 1310 , binder , box , coolant , d series , engine , hose , international , part , radiator , sii , tf727 , top , tranny |
| What are these NOS parts worth? | lonchair | Restoration Purists | 6 | 10-21-2005 04:50 PM |
| NOS Carb. | rideair | General IH Tech | 1 | 02-18-2005 09:53 PM |
| NOS parts cornucopia | janhighboy | General IH Tech | 0 | 01-03-2005 07:01 PM |
