Old 01-04-2012, 02:21 PM
JackOc's Avatar
JackOc JackOc is offline
Default Quick Fuel sender/tank question
Hi I am about to re-install my tank/skidplate & sender into my bare frame, cannot find pics in manual (i do have the manual and tried to find).......on the frame there are 3 nut/bolts on rear frame crossmember (left right middle) that look like they were pre-installed so that I wouldnt need to get a wrench on top once installed? however these move freely and would do no good.
Can someone tell me the correct install steps for tank/skid plate (just simple nut/bolts first?, lockwashers?) are they first ? then tank with another nut? then skid plate with another nut? Lockwashers? Then all that on the "J" bolts as well? Im confused
The body is off so its easy right now to access everything, but body is coming back from bedliner saturday
ALSO everything I have read just shows 1 wire to sender from gauge, what is the stud and nut for? Is that a ground that must be connected? The tank is undercoat covered (except where straps go its painted) will it still ground?
Thanks so much for your help ;-)
Jack
Old 01-04-2012, 04:47 PM
robgimmel's Avatar
robgimmel robgimmel is offline
Default Re: Quick Fuel sender/tank question
Which Scout do you have?
Rob Gimmel
68 800
3 spd trans
152 engine
A man who has nothing which he cares about more than his personal safety is a miserable creature who has no chance of being free, unless made and kept so by the existance of better men than himself.
John Stewart Mill
Old 01-04-2012, 04:48 PM
JackOc's Avatar
sorry 74 scout ii :-)
Old 01-04-2012, 05:57 PM
The tank does not attach to the frame,it hangs from the body with straps,and the J hooks go into 2 holes on the rear floor support.On the skid plate my 3 bolts have nuts that keep them from spinning so you just use nuts to hold the skid plate on,after the tank is in place
Old 01-04-2012, 10:03 PM
JackOc's Avatar
thank you!!!
ALSO....... Is the insulated post on fuel sender to be used for ground or?
I took this thing apart long ago and didn't remember,.....I feel stupid!
Thanks again
Jack
Old 01-04-2012, 10:15 PM
Will Marsh's Avatar
Originally Posted by JackOc View Post
thank you!!!
Thanks again
Jack
The insulated post is the sender connection, the ground goes to a spade terminal on a rivet beside it.
Will Marsh
Bill Cosby
www.redstate.com
body , crossmember , find , floor , frame , fuel , ground , manual , question , rear , scout , scout ii , stupid , tach , tank , top
Project: Scout 80 Electric Fuel Pump jtownley General IH Tech 13 03-28-2011 12:39 PM
Scout 800 b fuel tank question. Barney General IH Tech 2 03-31-2007 09:41 PM
Fuel tank vent question ozzy General IH Tech 2 03-12-2007 08:13 AM
Injectors--SD33T vs Mercedes OM617 Philabuster Diesel Tech 71 12-19-2006 03:01 PM
Gas mileage tips! Brandon A. General IH Tech 21 08-21-2006 07:07 PM
