Old 12-25-2011, 07:18 PM
76Binder's Avatar
76Binder 76Binder is offline
Default front bearings an seals
On bronco graveyard web site they have dana 44 bearing kits thats consist of 2 outer bearings an races 2 inner bearings an races an two seals for $48.00. I paid that much for one side from carquest need to do the wifes 1980. Do they fit the scout dana 44's i know axles are different but thought bearins would be the same. Hell of a good price timken bearings. Thanks chuck
Old 12-25-2011, 08:21 PM
Default Re: front bearings an seals
dont think they are the same as broncos have internal locking hubs and scouts have external,but they should be the same as 1/2 ton travelalls and pickups
Old 12-25-2011, 10:26 PM
Erik VanRenselaar's Avatar
Erik VanRenselaar Erik VanRenselaar is offline
AutoZone carries Timken bearings (or at least they used to a few years back).
'75 & '76 Scout IIs
Amateur radio operator, General Class - K6IHC
Work Smart, Not Hard...
Old 12-26-2011, 10:39 AM
WRENCH MAN's Avatar
The vast majority of the crap that the Bronco Grveyard sells is offshore CRAP!, I've installed lots of it for customers, I really feel sorry for the "do it yourselfer's" that try to install it at home with limmited knoledge!
68 Rambler American
72 1210 4x4
77 ScoutII
97 JEEP TJ
99 Yamaha YFS 200 (248)
Old 12-26-2011, 11:03 AM
heres how you find out if those cheap bearings fit:
pull your bearings and seal out of a hub.
find and note the bearing part numbers and the part number for the seal.
then go to any website like Timken and find your make model of vehicle and compare the numbers the manufacturer lists with the part numbers you found on the inner and outer bearing and the hub seal.
use only Timken bearings
and Id stick with National or CR brand grease seals when purchasing .
1980 , axles , bearings , bronco , dana 44 , external , find , front , hose , hub , part , price , scout , seals , website
D27 front bearings janhighboy General IH Tech 9 07-23-2009 11:39 AM
Front Wheel Bearings Blind Driver General IH Tech 4 07-07-2007 09:26 AM
727 trans dwebster8783 General IH Tech 18 01-01-2007 06:25 PM
IH 727 planetary pinions ScoutmanSV General IH Tech 5 08-07-2005 07:57 AM
Front Wheel Bearings? Munchies General IH Tech 8 04-26-2005 08:02 AM
