77 SII "Junior" 79 SII "Bessy" & "Thunder" RIP 79 Traveler "Cheyene" & "Emmy" 79 SII "Tiger" 79 Midas Traveler 79 Midas Terra 73 1110 T'all "Mama Fred" & "Papa Fred" 3 CubCadet 107s 72 1210 Flatbed "Buck" 74 100 "Grapperhaus" 73 1210 T'ette "I.M.S." 54 Reefer |
Yes the pin 5 of the relay DB/Yel wire should be the ground to energize the relay.
It connects pin 2 to pin 4 thru the NO-normally open contacts. Looks like a standard bosch relay. You could unplug the relay and simply jump across pin 2 and 4 to see if the pump runs.
A failed PCM is certainly one thing that would cause both no spark and fuel pump not running. I think you'll find 96 is OBD2 and so not compatible. Not sure about 95. In the unlikely event you don't find a PCM locally I have one for 94/AT. PM if interested.
Ok good news, the PCM might be ok. I reconnected the battery tonight, and jumpered the #2 and #4 pins on both the ASD, and the Fuel pump, with the fuel pump first. It pressurized the rail, but then nothing. I tried the same with the ASD, and no change either. When I connected the battery and then turned the ignition switch on, low and behold the CEL was on. Upon seeing this, I took advantage of the moment to retrieve the codes. First code, was a 12- this means the battery has been disconnected within the last 50 key-on cycles. Next was a 54, this one is no Cam Sync Signal at the PCM. Likely culprit here is the Cam sensor, so I will look to replace that and see what's up then. The last one was a 42, this indicates an open or shorted condition detected in the Auto Shutdown Relay Circuit. This could be due to me still having my jumper wire in place there, instead of the relay. I will work to clear the codes and see if I get something else to show up. Then of course the standard 55 which is the completion of ETC display on the CEL. Thoughts here, besides the Cam sensor??
From the AZ link I provided.
The FSM diagnostic procedures book says the "no cam sync signal at PCM" fault can be caused by any of these:
Carl,
You and Bill both brought up good points. I will be testing the unit, however as a side note, I am wondering just how much play a distributor should have with the rotor. The reason I ask, is that I noticed when I removed the pickup coil(cam sensor), there were wear marks on not only the ring inside the distributor, but also on the sensor. I noticed a little bit of play on the rotor end, which makes me wonder if the distributor bearing is worn. I was gonna replace the cam sensor anyways, as the damage I am seeing may be from a worn bearing or gear or something to that effect. I rechecked the trouble codes this morning, and 12, and 54 are still there, but the 42 is gone, probably from when I jumpered the connection. I am thinking the fuel pump may be bad, as it pressurized the fuel rail for a moment last night and then nothing else after that, and it hasn't since done it again. I will try and hook the pump directly to 12v and see what becomes of that. Then we can rule the pump out, but right now, I need to get a fuel filter so that if I need to get a new pump, it doesn't have to work so hard to get fuel up front. I'll keep you posted on more of my findings as I come across things. Jeff
77 SII "Junior" 79 SII "Bessy" & "Thunder" RIP 79 Traveler "Cheyene" & "Emmy" 79 SII "Tiger" 79 Midas Traveler 79 Midas Terra 73 1110 T'all "Mama Fred" & "Papa Fred" 3 CubCadet 107s 72 1210 Flatbed "Buck" 74 100 "Grapperhaus" 73 1210 T'ette "I.M.S." 54 Reefer Last edited by ihscoutlover; 12-30-2011 at 09:00 AM. |
Sorry I don't know the spec limit for shaft play. But you found something I think since the sensor is hall effect type and should not contact the ring.
I kind of thought the same thing. Now its finding the cause of the no fuel pump running that I also need to address. I'm thinking the spark issue is partially to blame on this cam sensor, but only time will tell what's the true cause of what's the problem. Funds have cut my parts quest a tad short, till I can find a true cause/effect and see if that cures it. I was thinking the whole distributor, since it actually comes with a new cam sensor. I'll keep you all posted and see what I come up with.
You won't get fuel if you don't have spark.
So if you jump the relay and the pump works then it should be fine. But it will not be turned on by the PCM if there is no spark. If the pump still doesn't work with the gnd applied to the relay then you may want to remove the replay and test it onn the bench. The diagram is normally on the top or side of the relay. If the reluctor is touching the pickup then you should probably look at replacing the distr. Cardone Reman/Distributor For your 1994 Jeep Cherokee 4WD 4.0L MFI 6cyl Price:$49.99 +Core: $32.00 Part Number: 30-4694
| 4.0 , adjustment , aftermarket , coil , crank , d30 , efi , electrical , external , fuel , grounds , ignition , obd , parts , power , repair , solenoid , spark , start , starter , starter switch , starting , switch , traveler , work |
| TBI Sudden No start issues... I'm Stumped | jcal73 | Injection Tech | 5 | 02-06-2011 03:41 PM |
| No spark please help!!!!!! | harvesterman93 | General IH Tech | 25 | 01-22-2011 07:58 AM |
| Spark Issue | IHScoutman14 | Injection Tech | 7 | 11-23-2006 03:21 PM |
| Erratic no spark | charlie_bomber | General IH Tech | 6 | 09-18-2006 08:00 PM |
| will it start this time | mfcerchiio | General IH Tech | 6 | 05-09-2004 06:27 PM |
