Old 12-21-2011, 01:10 PM
Default Re: Turbo+MPFI
Originally Posted by teenbmxer View Post
I really like that holley throttle body your using. Just have it machined to put in the iac. One question I have is if this setup is a batch fire or sequential setup? And will I be able to tune it enough to compensate for a cam in the .550-600 lift range and boost?
It is a batch fire.
The sequential is nice for emissions but you don't really gain anything in performance. And it takes more sensors on the crank/cam/distr to be able to time the pulses.
I'm working on a SFI system now but it won't be done for a while. Just not a priority.
Yes you can tune it.
Old 12-21-2011, 01:52 PM
teenbmxer teenbmxer is offline
Ok works for me. I'm in then. You should just boost one of your mpfi setups with me haha.I don't care either way about sfi either. I can't wait to see what one of these boosted sv engines will do on the dyno
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 12-24-2011, 07:24 PM
http://www.ebay.com/itm/BBK-4-Barrel...item35b6dff479
here is the link to a throttle body i was wondering if it would work or not? comes with tps and hole for iac
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 12-24-2011, 09:26 PM
Equipped with a standard carburetor style linkage assembly, this square bore design will work with dozens of factory or aftermarket 4 barrel manifolds.
Yes and no.
Yes it will work but only if you bolt a carb spreadbore to squarebore adapter on first.
Old 12-25-2011, 02:40 AM
I already have a couple of those but I planned on just getting a squarebore anywho. So sweet. Then I will get something like that
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 01-10-2012, 05:55 PM
Designed for use in custom applications, the BBK 4 barrel performance universal throttle body delivers unmatched performance at an affordable price. Equipped with a standard carburetor style linkage assembly, this square bore design will work with dozens of factory or aftermarket 4 barrel manifolds. It also features a universal style BBK throttle position sensor for easy hook-up on your custom application. Universal 4 barrel design – 1-3/4” Bores. Great for custom applications. Includes GM late model style throttle position sensor. Machined for late model GM IAC
@Bill- will you be able to make the ecu work with the late model iac and tps?
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 01-10-2012, 05:57 PM
also could you tell me exactly which ECU to purchase to set this up, maybe a link or years of 3 bar map sensor to use
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 01-10-2012, 07:03 PM
Yes any ecm/pcm will work with the TPS and IAC.
I can't speak for you but I am starting with the ECM mentioned earlier.
1227730.
With a power adder I will run the code59 software in it.
MPFI and turbo.
I'll have to look up the map sensor part #.
I already have my latest version of the wire harness for this ECM for MPFI on the IH and AMC V8 engines.
Going thru final checks of it now.
Old 01-10-2012, 07:43 PM
Ok then all is well and we shall be doing business real soon.
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 04-22-2012, 03:09 PM
just an update i picked up the 1227730 ecu at work today. and now have my wastegate, blow off, intercooler, and turbo
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
200 , 266 , 345 , 392 , adapter , bar , binderplanet , body , build , ebay , ecm , egr , electronic , engine , fuel , harness , manifolds , mount , overdrive , question , roll , spreadbore , swap , throttle , turbo
turbo 392 engine build part 2 teenbmxer General IH Tech 44 10-18-2012 10:19 AM
EBay Turbo Housings W.James Diesel Tech 4 04-15-2011 07:39 AM
Turbo/Intercoolers Theory & The SD-33T JordanP Diesel Tech 25 11-12-2004 05:03 PM
Visit to a turbo shop TonyLopez2 Diesel Tech 4 08-28-2003 10:41 AM
Turbo or "NO" dslsmoke Diesel Tech 7 01-23-2003 05:24 AM
