Old 12-22-2011, 08:29 AM
Default Re: turbo 392 engine build part 2
The BBF looks like a better fit then the BBC header. Maybe some block huggers would fit between the rails.
Looks like you could weld the IH flange straight to the BBF flange and just smooth the transition.
Are you cutting the guides for PC seals? If so, are you going to add some bronze sleaves to the guides?
I've heard of people running PCs on steel but I would be concerned with excessive wear from no lubrication. The bronze is self lubricating. The PCs might help reduce oil consumption when you start pressurizing.
Maybe even some ZGS-zero gap second rings to reduce blowby.
Old 12-22-2011, 02:46 PM
teenbmxer teenbmxer is offline
Well I'm already running bronze guides on the intake side. But on the exhaust side I was running umbrella style seals with regular guides.
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 12-22-2011, 07:58 PM
Intake valve dimensions
Exhaust valve dimensions
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 12-22-2011, 08:42 PM
Intake valves appear to be 2.078 with a .372 stem
Exhaust valves seem to be 1.731 with a .416 stem
Anyone remember what these valves are made off? I remember the shop telling me I never have to worry about them or something along those lines lol
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 12-22-2011, 09:26 PM
My pops was saying that they are stellite?
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 12-22-2011, 09:36 PM
Stellite alloy is a completely non-magnetic and corrosion-resistant cobalt alloy. There are a number of Stellite alloys, with various compositions optimised for different uses. Information is available from the manufacturer, Deloro Stellite, outlining the composition of a number of Stellite alloys and their intended applications. The alloy currently most suited for cutting tools, for example, is Stellite 100, because this alloy is quite hard, maintains a good cutting edge even at high temperature, and resists hardening and annealing due to heat. Other alloys are formulated to maximize combinations of wear resistance, corrosion resistance, or ability to withstand extreme temperatures.
Wikipedia is my source just incase anyone cares lol
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 12-23-2011, 10:36 PM
started working on the exhaust ports
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 01-10-2012, 05:53 PM
well got the whole rear end ready to bolt back in with the axle over leafs and i welded my diff. i had to cut down the bump stops and reflip the rear shackles to get enough clearance, but its going to be real low. next i have to start the front end axle over-maybe next month haha. The heads are taking forever to port, but i have the exhaust side done on 1 head haha. now a question i have for you guys that have done these heads before, can i remove the ledge that is in the bowl of the exhaust port that is right below the exhaust valve seats? i feel like rounding out the whole bowl and removing hat ledge and raising the roof of the ports would help alot on the exhaust side
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 01-10-2012, 06:27 PM
Here you go.
Old 01-10-2012, 06:40 PM
Well thanks, in that case I need to work on that first head more please check out my thread in injection tech please.
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
200 , 392 , air , aluminum , box , build , cage , cap , custom , engine , exhaust , grind , oil pickup , paint , part , pickup , problem , project , rich , roll , roll cage , rough , truck , turbo , valve
392 e engine W8CGQ General IH Tech 18 02-28-2011 07:14 PM
1978 Scout II 392 V8 Engine Problems... wavesailr General IH Tech 15 08-09-2009 11:07 PM
No holds barred 392 IC build John Donnelly The Skunkwerks 72 01-03-2006 03:15 PM
392 propane build up questions Rusty Escandell General IH Tech 12 10-04-2005 01:32 PM
Performance improvement 101 Breathing David Lang Diesel Tech 1 06-05-2002 03:20 PM
