Old 12-20-2011, 12:21 AM
teenbmxer teenbmxer is offline
Default Re: turbo 392 engine build part 2
the heads(kinda cleaned up)
the block is apart
Starting on the oil return passages and thinking about polishing the entire valley area instead of painting it its taking forever though lol
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 12-20-2011, 11:36 AM
I must have missed it earlier, but aside from wanting to build a more potent 392, what was wrong with the first build?
I'm actually more intrigued with the idea of getting a junkyard SV and bolting on a turbo to make good power, rather than the expense it always takes to BUILD an SV.
Granted, that relies on finding a few good-used engines and shoving as much boost in them as you can, but it sounds a lot more fun..
We Race Farm Equipment M4x4A #576
KE7VUX
Old 12-20-2011, 02:20 PM
Nothing was really wrong with the engine before. I just want to help oil return to the pan a little more and bump the compression to help spool the new turbo faster. Ill also be opening up the heads a little more and lightening my rods like you did
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 12-20-2011, 02:27 PM
Oh and I have to install a custom grind cam from comp for my turbo setup
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 12-20-2011, 07:58 PM
did a little more work on the valley area with my buddy today.
plan on polishing the oil passages in the head as well
Also just tryed out my new scale and got the weight of a few rotating parts
Whole assembly(with rod bearings and rings): 2032-33grams
Rod caps: 307grams
Arp rod bolts: 63grams
Rod bearings:64 grams for both sides
I plan on attempting to get the entire assebly weight (with rings not bearings) down to 1850 grams. but we'll see what happens
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 12-20-2011, 09:54 PM
800bman's Avatar
800bman 800bman is offline
Send a message via AIM to 800bman
Wow, I can't wait to see what this thing pulls on the dyno!
Old 12-20-2011, 10:30 PM
Yeah I'm not sure what to expect. I've seen a few basic blow through 350s and what not on the dyno that layed down some crazy numbers. I'm trying to aim high though. There's no saying how much power ill have(hopefully enough to keep me happy)
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 12-21-2011, 11:59 PM
Got the heads apart today. Everything still looks great, minus being really black(my poor tuning at 16 lol)
Now that the heads are apart i can finish the oil return passages and then start polishing the combustion chambers. after that ill open up the exhaust a considerable amount
and then hit the intake ports(which still appear untouched thus far)
Once im finished with all that(probably 3 weeks or so) ill have the heads milled some more(not exactly sure how much yet somewhere from .020-.040) and have the valve guides milled down(im thinking .100-.120 to accomodate a large custom grind from comp) and then that'll pretty much finish off the top end.
During the next 3 weeks or so ill also be tackling the job of lightening and polishing the connecting rods and having the rotating assembly rebalanced.
Ill more than likely be going with a 3bar mpfi setup as well (im speaking with bill-usn1 about specifics right now)
Ill be doing a few more things inbetween such as caging the truck and boxing the frame, but ill keep you guys posted and fully pictured
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 12-22-2011, 12:02 AM
haha oh and i work at oreilly auto parts and thats where i borrowed the valvespring compressor tool and disassembled my heads today. lol
also was looking into coating my pistons, thoughts and opinions?
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
Old 12-22-2011, 12:56 AM
BBF appears to have very similar bore spacing as well.
Heres a set of 79 2wd pickup 460 headers
and next to my 392 flanges
almost made for international haha. just weld on lol
Joe Sweeney
Tucson, AZ
1972 2wd Pickup
200 , 392 , air , aluminum , box , build , cage , cap , custom , engine , exhaust , grind , oil pickup , paint , part , pickup , problem , project , rich , roll , roll cage , rough , truck , turbo , valve
392 e engine W8CGQ General IH Tech 18 02-28-2011 07:14 PM
1978 Scout II 392 V8 Engine Problems... wavesailr General IH Tech 15 08-09-2009 11:07 PM
No holds barred 392 IC build John Donnelly The Skunkwerks 72 01-03-2006 03:15 PM
392 propane build up questions Rusty Escandell General IH Tech 12 10-04-2005 01:32 PM
Performance improvement 101 Breathing David Lang Diesel Tech 1 06-05-2002 03:20 PM
