Here is a pic Question is should I just wack on with big hammer to level it out or is there a better option. I know I will have tap the hole again. Thanks Jason |
It is hard to see exactly what it is doing in the picture but I say whack away! If you have something to spread the hammer whacks out a little more uniformly so you don't make it worse that would be good. Something like a real hard wood block or steel bar stock and lay it across the raised area then hit it.
Member - Gulf Coast Binders 1966 4x4 Travelette 1966 Stepside Pickup 1966 Scout 800 Sportop 1967 Scout 800 1970 Travelall - Project TraveLow 1971 Travelall 1974 4x4 Pickup 1976 Terra - Project First Degree 1977 Scout II - Project JPEater 1977 SSII |
i would back it up with a dolly.then hammer it back down. the other way would be to push the low spots up with a bullseye pick or a porta power.
AKA PYRO3256 Wanted 30's-50's IHC COE Truck 1979 scout II 1947 kb-1 |
| bar , bed , binderplanet , dolly , low , power , top , traveler , wood |
| Full sized 4x4 shifter linkage fix | DavidWTravelallfan | General IH Tech | 9 | 09-30-2011 04:38 PM |
| IH Engine Hot Start Fix (Aussie Version) | Will Marsh | BP IH Knowledge Wiki | 0 | 07-17-2009 09:23 PM |
| help-911-quick fix? | Holt Harlan | General IH Tech | 13 | 06-03-2007 06:46 PM |
| Tonto's Fix | scouting II's | General IH Tech | 5 | 07-15-2006 11:06 PM |
| Quick 'n Dirty (Fouling Plug Fix)? | Paul LaBar | General IH Tech | 9 | 07-14-2005 06:52 AM |
