AZIHR 2015
Old 12-10-2011, 04:01 PM
sdowney717 sdowney717 is offline
Default IH 392 cylinder numbering order 8-7- etc...
Would like a diagram showing the numbers
OK, looking at a motor, where is number 8 etc....
thanks
Old 12-10-2011, 04:09 PM
Will Marsh's Avatar
Default Re: IH 392 cylinder numbering order 8-7- etc...
radiator to firewall
2-4-6-8
dist/carb
1-3-5-7
1 and 2 are closest to the radiator, 7 and 8 are closest to the firewall
Firing order is 1-8-4-3-6-5-7-2, timed on #8
HTH,
Will Marsh
Bill Cosby
www.redstate.com
scoutboy74's Avatar
The even bank of cylinders 2-8 are on the left side and the odd #'s 1-7 are on the right side when viewed from the front of the vehicle on all IH SV8 engines. Firing order is the same for all and is stamped on the intake manifold.
Trever Whetzel
Fat White Boys
Binder Recovery
& Rehabilitation
SHOP NORTH
Old 12-10-2011, 08:04 PM
Is that the same for all v-8 of any manufacturer?
I am glad you guys posted. I found this thread and it seems they are saying even's are on the aft right side
but really they are on the aft left side.?
left right front back all depends on where your looking and sitting. I would have misread it and got it reversed.
Passenger rear is number 8?
http://www.binderplanet.com/forums/s...ad.php?t=95718
Old 12-10-2011, 08:12 PM
Dennis Bernth's Avatar
Yep, passenger rear is #8.
1980 Traveler SD33T, T19, D300 'Smoky'
77 Midas Traveler, future Terra project
73 Scout II w/Terra top, rusty plow truck on 33's
Old 12-10-2011, 08:16 PM
Banned
no not the same for all engine manufacturers.
not all engines are v 8,
get your self an IH engine manual and all of that info is detailed in it.
all references to/for a vehicle are referenced from the driver sitting in the car on drivers seat FACING FORWARDS for left and right sides,
and the proper way is to state 'drivers side' or 'passenger side'
Old 12-10-2011, 08:23 PM
scoutboy74's Avatar
Unless vantagepoint is otherwise specified like I did in my previous post...onnacounta the fact that I ain't usually sittin' in the driver's seat when I'm pokin' arount underneath the hood.
Trever Whetzel
Fat White Boys
Binder Recovery
& Rehabilitation
SHOP NORTH
Old 12-10-2011, 08:53 PM
Greg R's Avatar
Greg R Greg R is offline
No, Cadillac for example has the driver's side is even numbered and the passenger side is odd with a firing order of 15634278
Ford 302 is passenger side 1,2,3,4 driver side 5,6,7,8 front to rear with a firing order 15426378
Ford 351, 400 is the same numbering but a firing order 13726548.
Even day job mechanics need a book now and then to keep track of all the variations.
69 800
266 V8/4spd & D18TC/OD
4.27 D30/ D44
'56 S110 240 I6/4spd
'71 1210 345 V8/4spd 2WD
'67 Travelall BG246/4spd 2WD
Old 12-11-2011, 05:57 AM
jeff campbell jeff campbell is online now
whenever buying parts or discussing motors and or parts,it's usually described as if you were in the drivers seat..drivers side is left,pass., is right.same with body work and or parts.NOT from the front of the vehicle.
Old 12-11-2011, 11:47 AM
scoutboy74's Avatar
And that makes perfect sense in those situations. I'm not trying to be a contrarian, I get it. My point is that when one is actually looking at the engine and noting cylinder location, one is generally either in front of or off to either side, not behind it. You can't see the engine from the drivers seat unless the hood is removed, and even then not that well. So in this case, why not reference it the way you be looking at it from a practical standpoint?
Trever Whetzel
Fat White Boys
Binder Recovery
& Rehabilitation
SHOP NORTH
265 , 304 , 392 , binderplanet , body , car , cylinder , diagram , engine , firing , front , info , manual , number , parts , rack , radiator , rear , seat , show , state , work
392 ic swap for 345 also 392 casting # id jschuepb General IH Tech 3 07-05-2007 09:48 PM
NEED SOME ADVICE: IC392 or non-improved 392? Howie Lederfind General IH Tech 3 01-12-2007 10:23 AM
brake master cylinder usage question Blake W General IH Tech 11 09-09-2005 01:12 PM
