Old 12-06-2011, 01:13 AM
BigBamaScoutii's Avatar
BigBamaScoutii BigBamaScoutii is offline
Default Re: mechanical oil pressure gauge
Id pull the plug to instead of a tee but thats just my 2cents. If im not mistakin the oil plugs is smaller then the water. Thres 2 or 3 plugs on one side right.
345 , box , case , choice , coolant , engine , expansion , gauges , height , kit , oil , plug , remove , short , stalling , tube , tubing , vibration , water , work
345 low oil pressure problem Ga72scoutII Southeast Binders Association 21 12-19-2009 10:11 PM
Lucas Oil in Diffs and TC Shiner-Bock-Beer General IH Tech 7 07-16-2007 09:34 AM
Don't use Gear oil in your manual transmission - The sermon by brother Eldon! John Donnelly General IH Tech 0 11-29-2005 01:01 PM
oil pump question discodago General IH Tech 30 06-21-2004 09:58 AM
Checking oil pressure on a pulled motor? Dave_STL General IH Tech 22 03-26-2004 11:18 AM
