  #61
Old 04-10-2012, 08:03 PM
Bares62IH's Avatar
Bares62IH Bares62IH is offline
Default Re: My first Scout .... Living My Dream
One idea I came up with today is I'm putting left over wood from our new wood floors in our house in over the fiber glass floor of my scout or I'll use some left over laminate a friend maybe given me when he's done with the floor at his house either way I think it will look kinda cool some time I'd like to put In wood under the top so it had a woody look on the inside of the full top but I'd like to do the floor first. I was thinking about doing wood in the bed but Id just knar it all up cuz I plan on using my scout for work and I'm sure playing around or hauling my buddies dirt bike in the back up to silver would not go well. But I'll be sure to post pics of the floors when they are done.
Tonight Tim called saying he got shackle material from work and that he'd have the new shackles built for 30$ by Saturday. Originally I wasgonna have to pay a crap ton for material but this is a good run of luck as for the shackles. I hope to pick up the perches and u bolt parts thursday and then Id like to be able to have the axles and and up and test driving by next weekend.
Barrett
1962 Scout 80
  #62
Old 04-11-2012, 03:03 AM
guidolyons's Avatar
If you have trouble locating spring perches/u-bolts/ubolts plates, check out Ruff Stuff Specialties http://www.ruffstuffspecialties.com/catalog/ it's beefy, fair priced, and you'd be amazed at how much steel Dan can cram in a flat rate box!
I used Ruff Stuff spring hangers, shackles, perches, ubolts and ubolt plates from Ruff Stuff when I did my fool size axle swap.
  #63
Old 04-11-2012, 08:22 PM
Bares62IH's Avatar
So I found a ridiculous deal on the color of paint that my truck is for a paint that normally is super expensive it's a close out sale ....... However I found a color I like and am considering spraying myself this summer duplicolor has a color called sublime green pearl .... It's bright and its not a real 1960's color but I'll tell ya it is sharp and extremely tempting. But I am I'm heavy consideration of a repainted this summer to freshen it up.
Barrett
1962 Scout 80
  #64
Old 04-23-2012, 09:34 PM
Bares62IH's Avatar
Default Dana 44 swap up date
Got my bushingings pressed in and got the springs hung on the spring hangers. Tommarow hope to get my shackles finished and hang the rest of the springs and line up the axles.
Barrett
1962 Scout 80
  #65
Old 05-07-2012, 03:18 PM
Bares62IH's Avatar
Axle swap update
Did the swap No changes had to be made to my drive line to accomadate the 44's
only had to do axle shims in the front to correct pinion angle
theres alot of people with alot of opinions on here ...
so far my build has gone nearly bolt in.
no drive shaft length issues nothing
Heres some pictures of my shackles and just some pics from working on getting the bushings out
Check out the comparison photo on the shackles I may round off the corners later but right now im just worried about getting it all put together. U bolts were supposed to be here today but they havent showed up yet ...... Anything Scout ? can you explain why this has yet to happen ? Got u bolt plates that I had made by tim the guy helping me do the build
to adjust the rear pinion angle we just weded in the new axle pads at a different point
Barrett
1962 Scout 80
  #66
Old 05-07-2012, 03:22 PM
Bares62IH's Avatar
just measuring for adjustments for the new pad and a possible paint color and a pinion shot when i was looking for a better angle ..yes i know that was a horrible angle
if you look above you can see the shackle size comparrison
Barrett
1962 Scout 80
  #67
Old 05-07-2012, 03:26 PM
guidolyons's Avatar
How is the caster angle? That's the important angle if you want it to track straight and not wander all over the road.
The top of the knuckle should be tilted back ~5*, if you have long shackles, and a shim for to tilt the pinon angle up, the caster is usually off (tilted too far forward) unless the previous owner already did a "cut and turn" on the knuckles to correct the caster angle.
  #68
Old 05-08-2012, 09:13 AM
Bares62IH's Avatar
Haven't checked gotten the shims in yet to see. I ordered 4* Shims and we are gonna get it all bolted in and see what we get once it's all togather and go from there. Hope to get it bolted togather sometime next week so I can get out to the dunes for memorial day.
Barrett
1962 Scout 80
  #69
Old 05-20-2012, 08:37 PM
Bares62IH's Avatar
Got every thing almost finished to have my build drive able.
Here's a run down on everything as of today
Dana 44's
Lockers front and rear
4.88 gears
Front disc brakes
New shackles
4 inches of lift
New u bolt plate
Ranch rs 5000 shocks
New shock mounts
Thrush glass pack
New u bolts
New axle perches
Just standard upgrade stuff
4* axle shims
Pretty much hope to have it all bolted up tommarow and Wednesday
So I can take it up to the dunes this weekend. More pics coming this week
Barrett
1962 Scout 80
  #70
Old 05-29-2012, 09:51 PM
Bares62IH's Avatar
Finally finished measured out to about 3.5 inches give a little or so its close to four.
Steering was solved with a modified pitman arm pictures will show that
i will go into details as i post photos as well as ill write up how i did everything and how i did it on a budget.
very pleased with the out come.
Barrett
1962 Scout 80
196 , 4x4 , brakes , build , car , craigslist , deal , diesel , dolly , first scout , florida , for sale , fun , pictures , price , project , rust , sale , scout , search , shop , short , spring , start , wanted
My one dream: a solid Scout II Matt G General IH Tech 2 04-19-2004 02:17 PM
