I thought I would post the power steering swap I just finished on my 800A For a box I used a box from a 1995 jeep grand Cherokee. When I picked up the power steering box I also picked up the steering linkage from the box to the column. The reason I did this was that it had small u joints at both ends and was a collapsible . Now my 800 already had a I assume a factory type collapsible shaft from the column to the manual box . But it had a rag joint on one end and the common T type joint on the other where it attached to the box , which was in rather bad shape as well and I couldn’t get the angle I needed so as to set the box level with the frame. What I found was that the bottom end of the Jeep shaft was the same ID as the OD of the bottom end of the scout 800 shaft solid shaft . The jeep shaft is also collapsible and about 21/2 inches from lock to stop . IE its not pinned in place like the scout shaft . They slide right inside each other nicely, no slop or play IE a good tight fit . So I cut the Jeep tube off just behind the steering column joint . This aloud me to slide the scout shaft 1 inch inside .After cutting the scout shaft off to compensate , I then slid the two together , then welded things up and cleaned up the weld .. So now I have the U joint at the box , thus giving me a greater angle to the box and the ability to extend the shaft to my scout steering column as I have the ability for 21/2 inches of adjustment. probably someone already has found this out and noted it . but i though i would post it , just in case . first is of the box . you will notice that i have a front cross member . So I had to notch out the back cross member . This I will box in once I do the finish welding . I still have to weld up the upper support for the box . ![]() as to the steering linkage . Here is the joint that was on the steering column side of the shaft I took from the grand Cherokee, this is next to the bottom half of the link from my 800 ![]() Originally the joint was attached to a shaft that had another shaft that slid up inside it . Which in turn had a joint at the steering box end .. The shaft on my 800 did the same thing but was longer . IE I had a shaft within a shaft While I was pulling the pump from the grand Cherokee, I though the shaft looked very close to the lower shaft on my scout so I grabbed it to . After getting home and micing the two lower shafts , I found them to be the same . So I cut the joint “again the one you see , off of the larger tube of the GC This photo shows the lower shaft end of my 800 and the inside of the upper end of the larger shaft of the GC ![]() After cleaning up any burrs , you can see that they fit together very clean and tightly . ![]() Then I cut the lower shaft from my 800 down so as to have it slide 1 inch into the upper shaft of the GC and so the two upper shafts butted together . What this gave me was the ability of the shaft to still be collapsible and have the Bergson joint at the box Now I haven’t finished cleaning up the weld yet but here is a shot of the new shaft ![]() Im sure you all notice the torch cuts . Originally when I got the 800 the PO had done a patch job on doing a PS box . I did not think it was safe so I took it all off and put a manual box out of my other 800 back on .. The 800 also had a 4 inch body lift and the PO had used a hack saw to hack up the radiator support so as to get the steering shaft to clear . Since that was already done , I just cut all that out and will come back and weld a new section back in and clean this all up . If this had not been done all I would have had to do is notch this section just a little to clear the shaft . I should also note that the grill will not need to be modified at all to clear the box. Now , having the Bergson joint at the box this left the rag joint which bugged me . so i got to wondering if the GC steering joint would fit . this joint is the one i showed in my first photos . so i pulled the column out and took it apart . what i found is that the shaft is alos the same OD as the ID from the GC tube . so i removed the rag joint flange . cut 1 1/4 off the column housing . put all the bushing back into the column i then ground the flats on the shaft and slid the GC upper joint into place. then drilled both for a retaining bolt . dropped the washers , spring and seat . put the shaft back into the housing . replaced the wheel , then put it all back in . now for the bottom half .. i knocked the old rag joint flange off . this section of the scout steering linkage is a tube . it was the same OD as the connecting side of the GC joint . so what i did was turn down a piece of bar stock so that it slid 3 inch’s into the tube . i then ground the flats . inserted the this into the tue and welded it up . for just alittle what if /just in case , i drilled and added a retaining bolt . not that its should be needed but if figured , it couldn’t hurt . so now i have a colapsable shaft with U joints at both ends of my steering . IE one down at the box and one that replaced the rag joint . all for 7.00 from Pick a part . i should also note that the upper joint on the GC is also a vibration joint in that its got the hard rubber internals to reduce road vibration . here is a photo i should have noted concerning the upper rag joint flange thats attached the the steering wheel shaft . again i dont know if Bill or George has noted this before . in the past i have read that upper flange was not removable . after inspection it looked to me like the shaft was splinned to fit the flange . Then the center of the shaft was counter bored what appears to be 3/8 of an inch . This aloud the flange to be set to the splines , then the shaft flared so as to lock the flange in place on the shaft . So I set the shaft into my drill press , dropping it through the center hole on the drill table . Using a ¾ drill bit I removed the flair from the inside of the flange . The flange then just pops right off. This also left approximately ½ an inch of splines on the shaft . Im not sure those splines would be useful to know about but ill mention them just in case. Again I want to make clear that I did not have to cut the actual solid steering shaft from the wheel to the upper rag joint . I only cut down the outer column housing so as to provide enough room for the new joint to slide fully onto the shaft Taking alittle out of this section thus exposed the amount of the shaft I needed so as to attach the new joint and still gave the internal parts all the correct fit . Here is an old photo that shows my column with the rag join prior to the modification and the area I cut off the column tube . ![]() This modification was of very little cost and appears by the number of 95 GC at the pick a part , its readily available . Now that I have done it , I probably could do it again in an hour or so . The plus IMO to this mod is that a) it does away with the rag joint while at the same time providing for the dampening effect of the stock rag joint b) for those of us with body lifts or other mods that require a greater degree of angle to the steering . this completely removes the need to have to change the angle of your column . Thus negating all the other issues that in some cases also have to be dealt with concerning column angle c) you get a fully collapsible linkage that can be simply compressed to remove . IE no pulling the pump or loosening up the steering column to take it out There is one drawback though. If you have to replace the upper joint , your going to either have to remove the steering wheel so as to take pressure off of the lower inner spring . Either that try and fight compressing the spring from the outside as you push the new joint back up in place . So now the upper box perch welded in and the frame reinforced and the cross member that I notched out , boxed back in . then I shot a coat of paint. I made this mount from 1/2 inch well casing . Then supported it with 3/8 plate on the frame . for the gussets i used 1/4 plate ![]() While waiting for the paint to dry I started trying to figure out how I was going to clean up the issues with the old body lift . I had some scrap diamond plate out along the shop so I cut a template and flanged the edge to match the area that was cut out of the radiator mounting . Stepping back , it looked kinda odd so I did one for the other side even though there wasn’t anything wrong over there . ![]() As you can see I was starting to have some rust issues around the battery and bellow it so I decided now would be a good time to Rhino line everything behind the grill but the fan shroud . So out cam the wire brush for my grinder and I went at it . Shot 3 coats of Rhino liner , let it tack up and re installed my diamond plate . ![]() As you can see in the above photo , I have the Power steering box bolted back in place . Here is another closer photo with the hoses installed ![]() Now with my lift , if the PO had not hacked up the bottom of the driver side radiator support, you can see that only a little notch would have been needed to clear the steering shaft . Also here is a photo of how the box sets in relation to the grill . You can see that even without the body lift , no cutting would be needed to the grill at all ![]() Here is a shot of the underside . The grill clears by a good inch ![]() i got the PS pump bracket reinforced and the vacuum pump mounted . I also added a vacuum pump from a 1990 ford diesel I tell you what . I don’t know why I didn’t do the vacuum pump along time ago. Even with a dry windshield, the wipers are running nicely . No more dead wipers when I hit the gas.
Nice Job
looks good, did basically the same thing on my scout,i used a steering box from a 93 dodge truck . the joints where from 98 cherokee.
I thought about going with an outside the frame setup . But for some reason despite all the other changes I have done to my 800 , I just have an issue with cutting on the body .
I gotta get down to the Pick a part and get a Vacuum canister and finish plumbing in my vacuum pump . Its working very well without one . But I think it will work better if I plumb in both the pump and engine vacuum. Im just hoping this time its not as long between being able to work on her |
most all the work i have done on mine was this spring and last year,didnt touch it all summer do to lack of extra time and money.did gather more parts for it over the summer tho.also been helping my son on his progect,hes got a 37 chevy truck hes making hot rod out of. hope to get back on my scout this winter.
......__________ .... |__________| .[]<|0|_______|0|>[] ....|.... |.v....|.....| ....|___|.......|___| |
im thinking that the reason you didnt have to cut the inside finder well was because yours was a V8 scout thus already had the box mounting outside the frame.
With 4 cyl scouts like mine , the box is mounted inside the frame. Now granted that with my body lift , I may not have had to cut out any of the inside finder .also i did not use the original mount . i cut it completely off , thus the new box sets right to the frame vs 2 inchs off the fraim I had a hard enough time excepting cutting the small area out of the drivers side fire wall when I did the engine swap . I just don’t like the idea of cutting the body all up . I know its kinda dumb , but that’s the point of the mater .At least on this 800 . now on my other one . pffft it has so much cancer that most of the cutting has probably already been done for just about any mod one would want to do
You mentioned that you had to notch the frame. Do you think you could have avoided notching the frame if you had put the steering box on a rake? Would the pitman arm hit the bottom of the frame if the box was raised enough to clear the cross member? The first question is probably answered by moving the box forward but the pitman arm question would probably still need to be addressed. I’m curious as using the parts you did with mounting the box on a rake looks like it will work well for me. I just need to keep the steering shaft in the stock location. If I lower it, it will hit my power steering pump. If I raise it, it will hit the radiator. The photo of my radiator shows the tight clearance. Junk yard here I come. |
you could get alittle angle out of it . more angle if you dont have the front crossmember like i did . with a stock body hight , you should be able to get the same or at lest very close to the same steerng shaft location as well .
when you get the box , just make sure it has the dropped pitman arm. also remeber , moving it forward to far couldrun into an issue with the grill |
Great writeup, great info. How about more info on the vacuum pump?
'71 800B,345, T18 wide,20, 60, 14, 37's, 57's, 63's, orb of traction, stretched to 105"s...... Swapping out to a vortec, 4l60e, np241 for a 2011-12 winter project. with a np231 6 planetary waiting for the doubler upgrade. anyone need some IH stuff?
| 800 , bar , body , bushing , cam , cap , column , front , ground , lift , lock , number , paint , parts , photos , power , power steering , pulling , radiator , rag joint , scout , scout 800 , steering , windshield , wipers |
| Scout 80/800 Serial Numbers | rlireland | BP IH Knowledge Wiki | 0 | 10-27-2010 08:38 PM |
| power steering in acout 800 | ScoutBoy66 | General IH Tech | 2 | 09-09-2009 07:21 PM |
| 800 4cyl power steering. | Jack H | General IH Tech | 3 | 02-23-2008 06:48 PM |
| Ford power steering box Scout 800 | Blackdog | General IH Tech | 18 | 10-10-2005 07:55 PM |
| Pics of steering column for 800 w/Borgesons | grannygear | General IH Tech | 4 | 06-08-2003 08:22 AM |
