I know some of the D series owners here have been having problems getting radiators. I talked to one of my buddies here in town who owns a radiator shop, and he said it shouldn't be a problem, so I let him borrow my two of my stash for measurements (one auto, one manual) and he said as long as he had the original tanks, he could do either one for $300, plus shipping. He said if there was a lot of interest, he may could cut the price even lower. Let me know if anyone is in need. |
Mitch,
good work. That, friends is one heck of a deal. I paid closer to $400 each for mine that were fabbed up locally. JJ in TN
1973 Travelall 4x4 1110 392 727 TF 1973 Wagonmaster 4x4 1210 392 727 TF 1974 Pickup 4x4 100 392 4 spd lifted 1975 Flatbed 4x4 200 392 4 spd 1976 Scout II Diesel 4spd Dana 300 1979 Scout II 345 727 TF Project (Mrs JJ's) Now we have SIX IH's and a State Farm Fleet Discount
I was quoted double that at a local shop to recore mine. JR has been sitting for going on 2 yrs now. I need to get one in there and get that truck back on the road. I left my radiator and another potential core at that shop and they're likely long gone.
I need an auto rad and I'm definitely interested! Mitch, any chance you need a spicer 5 spd with SV bell, clutch, & chelsea PTO?
'77 SSII - 304, T19W '71 1010 - Johnnie Reb, 304, BW auto |
I agree. We paid $450 two years ago.
Tim 73 Travelette 1210 Camper Special 79 Traveler -- again! Life's a garden. Dig it. |
Jeff I should have a set of tanks and brackets ,I had to many bad ones and took off brakets and kept tanks,if you cant get yours back and need some I will dig them out.
I thought it was a good deal, he can also do Scout II and 800 radiators, and he does tank linings, but I didn't get a price on those. I just happen to have some loose D series radiators and I knew there was a problem getting them at a resonable cost.
Thanks to Mitch and Robby a D series radiator has been recored and will ship to my house tomorrow. Can't wait.
I'll keep you guys posted. -Jeff
Got the radiator this week and it looks like a quality job. I can't even tell it's not the original core aside from the fact it's perfect and new. A few questions before I drop it in ...
What's the best way to "flush" the old coolant from the engine? I've just replaced all the heater hoses because they were trash. When doing so, I flushed the heater just by running water through it with the garden hose. What I flushed was very black (same as what I drained from the entire system) as if this system has had a leak stopping additive used at some point. I guessing the block is still full of this crap too. How do I go about flushing it? Lower hose is off, upper is on. I've got a new lower hose. I can easily fill it from the heater hose connections. Should I just plug the lower water pump connection, fill it up, and then let it drain from the lower water pump connection. Do this a few times?
I might suggest using you old rad to prevent any crap getting into your new one for this process, but here goes. Drain old coolant, fill with tap water with all hoses in place and heater valve open. Allow it to run till the thermo opens and drain. Do this a couple times. If you choose to you can add some coolant system flush during one of the cycles. Last time you fill use only distilled water. Allow thermo to open one last time and drain. Throw your new rad in and fill with 50/50 mix of antifreeze and distilled water. Good to go.
72 scout II trail rig .SOA 266,t-19 wide, dana 300,linked rear 92 Dodge 250 4x4 12 vavle Cummins. Stock...... for now....... http://oldironoffroad.com/ http://www.southeastbinders.com/ |
| 800 , brake , broke , clutch , coolant , cost , d series , deal , engine , hose , manual , plug , price , problem , pto , radiator , scout , scout ii , shop , tank , tire , truck , water , work |
| C series front sheet metal on a D series? | Moosebrew | The Skunkwerks | 5 | 04-21-2011 01:08 PM |
| C series T'ette cab/ bed on a D series T'all chassis? | fungus | General IH Tech | 6 | 04-14-2011 10:11 AM |
| What year is it? | eightOsix | General IH Tech | 30 | 08-11-2009 04:20 PM |
| series 3 to series 4 carriers..... | Ricky77 | General IH Tech | 7 | 05-06-2005 03:28 PM |
| 3 series vs 4 series carriers | Ricky77 | General IH Tech | 1 | 11-24-2004 08:25 PM |
