Old 10-03-2011, 08:51 PM
NC Scout's Avatar
NC Scout NC Scout is offline
Default Front Axle Question 1971 Scout II
When looking at either end of my front axle right before the ujoints, the passenger side is pushed out a little, the driver side is flush. Can someone explain, is this right??
Old 10-03-2011, 09:23 PM
Eric VanBuren's Avatar
Default Re: Front Axle Question 1971 Scout II
No that isn't right, I'd say you are missing the snap ring that goes on the end of the stub axle that is supposed to keep it tight up against the seal. If it's been running like that it wouldn't be a bad idea to tear it down and inspect the spindle bearing since it may have become contaminated.
Old 10-03-2011, 09:26 PM
nctom nctom is offline
X2. C clip is off of it. If it were your rear axle, it would have passed you going down the road.
Old 10-04-2011, 01:00 PM
NC Scout's Avatar
Thanks for the responses. Is the clip accessible from the differential? I'm looking at my manual and don't see snap rings.
Old 10-04-2011, 01:03 PM
Carl Wiese's Avatar
Carl Wiese Carl Wiese is online now
The Dana axles IH used don't have C-Clips. I think by snap rings Eric meant within in the spindle.
CoD - Prodigal Son
Old 10-04-2011, 01:26 PM
NC Scout's Avatar
I have the Lock-A-Matic hubs. I'm looking at the diagram in my manual (CTS2304 page 2209-H middle diagram) and see a few lock rings, can anyone tell me which they would think is the culprit?
Never taken the hubs off.
Old 10-04-2011, 04:57 PM
Take them off, clean up and inspect.
Old 10-04-2011, 06:13 PM
Mark Ashford's Avatar
Moderator.. or something
It will be an external snap-ring on the end of the stub shaft as at pokes out of the spindle. Take the cover plate off the locking hub and you shoud see it (maybe after a little cleaning). Take both sides apart and compare.
Old 10-04-2011, 09:07 PM
Yes the snap ring I was referring to is the one on the stub axle under the outer body of the hub. That snap ring will not show up in the exploded diagram of the hubs since it is not technically part of the hub.
Do as Mark stated and pull the outer hub body bey removing the 6 bolts and compare the 2 sides. You'll likely have to clean some grease off but you should then be able to see the snap ring on the one side.
Old 10-05-2011, 12:06 AM
jauringer's Avatar
Interesting thread. Keep us posted on what you find. Mine does the same thing but the snap ring mentioned is attached on mine so that might not be your problem.
Jason
72 Scout II - Flame Red
SV313/TBI-7747/727-TF2/D20-Twin stick
304 , 345 , axle , axles , body , broke , clean , diagram , differential , external , find , front , hub , lock , manual , matic , part , pictures , question , rear , rear axle , scout , scout ii , truck
Dana 44 Front Axle Parts List Architectdave General IH Tech 6 04-24-2010 07:01 PM
Scout II Front Axle Right Springplate Assemblies in STOCK.. Mike Ismail IH Parts America 0 06-21-2007 02:29 PM
Front axle ring and pinion question Tom General IH Tech 12 03-29-2006 07:14 PM
Scout 80 axle upgrade???? SII?? chevy6scout General IH Tech 1 06-03-2004 05:13 PM
Ford knuckles/spindles on a D44 Scout front axle? Cactus Cowboy General IH Tech 1 01-26-2004 12:06 PM
