Old 09-28-2011, 09:23 PM
BanjoBend's Avatar
BanjoBend BanjoBend is online now
Default 14 inch air cleaner
i recently installed a 304 into my 78 terra. when i purchased the engine it didnt have a carb or air cleaner. i had an old holley 2150 lyin around and a 14x3 air cleaner. after buying a riser so the air cleaner would clear the t-stat housing, my hood wont close. Is there anyone running any other aftermarket air cleaner assembly that looks good and has plenty of clearence? I thought of using a 1" element but thought it would look kinda funny. I dont have the oem assembly so i dont have a reference for size.
thanks.
PS I know i should run a holley 2300 carb, but a free carb is better than no carb.
78 Terra, 345 w/ cam and headers, t-19, D-20, Lincoln locked 44's, 33x12.5 BFG's, Cage and rock sliders
Old 09-28-2011, 10:13 PM
Will Marsh's Avatar
Default Re: 14 inch air cleaner
thanks.
IME, if the air cleaner base is flat (bottom of element level with the mounting flange on the carb) it will clear the T-stat housing without a spacer on any of the standard air cleaner flange carbs. I usually run a 1" spacer under an Edelbrock 14XX carb. If you don't run a spacer under the carb you might need a spacer above it depending on the carb. In any case you want insulation between the carb and manifold as the IH manifolds are HOT!
On a ScoutII/Traveler this allows a 2" element with a flat top, but the wing nut and stud will dent the hood. Replace them with the appropriate length bolt and you're golden. This works with a 2300/41xx Holley or 14XX Edelbrock for sure, others you'd have to check.
HTH,
Will Marsh
Bill Cosby
www.redstate.com
Old 09-28-2011, 10:24 PM
raise the hood latch . . .
Old 09-29-2011, 12:22 AM
BanjoBend's Avatar
I didnt install a spacer under the carb but i did use the 1/4" insulating base gasket.
It will actually work with the air cleaner top upside down, so the 2" filter would probably do it. Ill see if i can get one tomorow.
Old 09-29-2011, 08:58 AM
Early 70's Cadillacs had an air cleaner of large diameter that set lower than the carb top that will fit your application.
Old 09-29-2011, 10:12 PM
jauringer's Avatar
jauringer jauringer is online now
You can also buy an offset air cleaner to miss the thermo housing. The setup IHON sells has a base plate that drops down below the top of the carb to allow for a bigger filter.
72 Scout II - Flame Red
2300 , 304 , aftermarket , air , air cleaner , carb , carb. , engine , filter , fun , gasket , holley , holley 2300 , scoutii , size , spacer , t-stat , terra , top , work
Basic Trouble Shooting Bill usn-1 Injection Tech 1 11-25-2010 11:27 PM
Hose diagram / air cleaner for a 61' 152 John in KC General IH Tech 4 09-06-2005 05:47 PM
392 Travellette air cleaner housing Special Ed General IH Tech 3 06-18-2005 09:46 PM
Holley 2300 Air Cleaner? robtarr General IH Tech 6 09-16-2004 05:29 PM
air cleaner temp sensor (vacuum) mdmcs1 General IH Tech 3 12-05-2003 06:48 PM
