Jason Honeycutt 1978 IH Scout II EFI 1978 IH Terra trail rig G R C built S E B A www.youtube.com/jhnyct |
yes.
Just push it out the firewall and then take a really good razor knife with new blades and cut the bottom in a straight line from one end to the other. Then it can be peeled off the harness. It's molded around the wires so it's tight. The vans are easier since they go thru the floor under the drivers seat. If you disconnect the harness at the ecm you can pull the whole thing down to work on it.
As I am building this harness, I wonder if it would turn out clean if I did what GM did with the vans. It would be easy to build a bracket for the ECU under the seat and there would be no extra holes to make in the firewall. Just alot more length of wire. Who knows, maybe next time.
| aftermarket , binderplanet , clean , ecm , find , firewall , floor , harness , part , pulling , rough , seat , turn , work |
| Scout II firewall Insulation | HorseHung | General IH Tech | 1 | 08-25-2011 03:03 PM |
| New (NEW) PCV Valve Grommet | Thomas | General IH Tech | 20 | 12-30-2010 09:38 AM |
| Question on my Firewall | Mumpy | General IH Tech | 7 | 11-04-2010 02:38 PM |
| What are these nuts on the firewall for? | Rhees | General IH Tech | 6 | 07-28-2009 09:21 AM |
| What is that on the firewall? | rebelscout | General IH Tech | 7 | 02-17-2004 02:44 PM |
