Thank you, Mark |
Grind them off.
Be smart about it and you should have no "boom" issues. Or use a sawsall, or even a nut-cracker if your really paranoid. I'd just grind it. |
Are these the skid plate bolts or gas tank bolts ? Skid plate grind or sawzall them off. The gas tank strap bolts have a hook and don't need to be held down. Just spin em off.
I assume it is a skid plate over the gas tank. Either that or it is the strangest gas tank I've seen.
Many aftermarket 33 gallon tanks have built-in skid plates, some of them bolt to the frame, some bolt to the body. |
If you cut or grind the bolts off, how are you supposed to replace them if you still do not have acces to the top of the bolt?
If they are the same 3 bolts I am thinking of, they are just carriage bolts. Once you grind/crack off the nuts the bolt will just push through the top and then you can get to the "J" bolts on the tank strap.
Joker51
Joker51 1979 Scout Traveler with SOA, 33" tires, 345, 727 tranny |
Cut them off. New tank straps & J-bolts are a dime-a-dozen.
It is not woth your time trying to save them.
1975 "200" AWD Western North Carolina SEBA / Southern Scouts |
Tank straps are expensive
Just an FYI...I had to remove the skid plate from my Terra and was having trouble with the back bolts as well . Everyone here says to cut or grind them off. Not necessary. If you look closely, between the skid plate and frame, there is a nut. You need to put a thim open end wrench on this nut to keep the bolt from spinning so you can remove the bottom nuts holding the skid plate on.
If you cut or grind them off, you are defeating your purpose. You will never be able to get new bolts to work (unless you cut a hole in the frame to access the head of the bolt) without double nuting them. Be wise...inspect before you leap. Jim |
| 1979 , 33 gallon , aftermarket , body , bolts , choice , frame , gas , gas tank , grind , mounts , oil , removal , remove , rust , strap , tank , terra , top , traveler , work |
| Scout 80 gas tank removal...How? | scout-ED | General IH Tech | 13 | 01-12-2006 09:00 AM |
| gas tank removal | Wayne H | General IH Tech | 6 | 01-11-2005 07:42 PM |
| Q's concerning gas tank mod for 800 | Joker | General IH Tech | 5 | 01-07-2005 06:41 PM |
| Gas Tank Removal | Pablo | General IH Tech | 25 | 01-14-2002 11:53 PM |
| Gas Tank Removal | Dano | General IH Tech | 2 | 10-20-2001 12:41 PM |
