Old 08-12-2011, 05:25 PM
murfman55's Avatar
murfman55 murfman55 is offline
Default Intake manifold problems
On the bottom side of the intake manifold there are some circles that appear to be plugs of some sort. I have one that rusted through, are these replaceable? If so where would I get them? Thanks!
74 4wd Scout II
Old 08-12-2011, 05:31 PM
gillis51 gillis51 is offline
Default Re: Intake manifold problems
They are 1 1/8" welch plugs. Check useful parts list for the part no. You can get them at NAPA
Old 08-12-2011, 05:53 PM
Mark Pietz Mark Pietz is offline
Hardest part of replacing them is getting the manifold off and then back on. Simply pry out the offenders and tap in the new ones. If one is rusted through, the rest are sure to follow. Do them all and then forget about 'em.
IC 196, 4-speed, 3.73 gears
Old 08-12-2011, 07:17 PM
Eric VanBuren's Avatar
While you've got it off it's a good time to do the valley pan gasket and PCV grommet.
Old 08-12-2011, 07:27 PM
robgimmel's Avatar
robgimmel robgimmel is offline
If you can find brass plugs, you will never have to worry about them again.
Rob Gimmel
68 800
3 spd trans
152 engine
A man who has nothing which he cares about more than his personal safety is a miserable creature who has no chance of being free, unless made and kept so by the existance of better men than himself.
John Stewart Mill
Old 08-13-2011, 06:10 AM
Super Mod from Downunder
Don't be too sure about that as some of those plugs are in exhaust gas recirculation ports!
Old 08-13-2011, 08:14 AM
murfman55's Avatar
Thanks guys, new gaskets and seals all around is planned so a few more plugs won't hurt! Thanks again.
74 4wd Scout II
Old 08-16-2011, 01:43 PM
murfman55's Avatar
This maybe sort of a stupid question but I looked up the part from the useful parts list at napa and what it shows looks flat across it and what is on the bottom of the intake manifold is more convex in shape. Does it really matter as long as it seals the hole?
74 4wd Scout II
Old 08-16-2011, 02:38 PM
Check my post under useful parts and use the model no I posted. It is current and corect for a 79 345.
Old 08-16-2011, 03:03 PM
murfman55's Avatar
I guess I was expecting something more like a freeze plug.
74 4wd Scout II
345 , clean , exhaust , find , gas , gasket , hose , hot , machine shop , paint , part , parts , plug , problem , question , rusted , seals , shop , start , stupid , tank , valley pan
V304 Intake Manifold Gasket Question Peter Ferris General IH Tech 8 09-26-2007 09:41 AM
intake manifold decking problem tim v Sonora Desert Scouts (Arizona) 3 07-10-2006 10:07 AM
? on Intake Manifold Bolt torque and Silicone ih200 General IH Tech 1 08-08-2005 09:42 PM
350 intake manifold leak slowboy General IH Tech 3 06-29-2004 01:32 PM
Vacuum leak at intake manifold Tim Perry General IH Tech 2 05-06-2004 09:18 PM
