Keep in mind that timing also affects vacuum. So you can adjust the distr at idle to see the affect it has. Quote:
I don't know the condition of the fuel injectors, I was just told the previous vehicle ran good. I took a couple short videos of each injectors spray while the motor was at idle. I was wondering if they look like they have a good spray pattern. thanks, Scott http://dl.dropbox.com/u/27638873/MVI_2043.AVI http://dl.dropbox.com/u/27638873/MVI_2044.AVI |
How did the vacuum reading compare to the map reading?
Fuel spray looks ok. Is the timing working properly?
I tried swapping out the distributor coil and control module and it made no difference, so I guess the ignition is good. The mechanical advance of the rotor moves freely and doesn't seem to bind. I don't know what else to do to test the distributor/timing. Scott |
Things are a little different/confusing when using a pressure conversion vs the manifold vacuum. Even the calc I posted isn't correct.
From the parts FAQ. Quote:
Here's a complete conversion. If your the one running the fuel only then the timing is all in the distr.
Bill USN-1 ![]() Click a link below that meets your needs! Either DIY or let me help. COMMITED TO HELPING PEOPLE "PROPERLY" INSTALL EFI Learn to do it right. May be the answer to all your fuel injection needs! WANTED-Holley Distributor Last edited by Bill usn-1; 08-21-2011 at 02:17 PM. |
Thanks for the MAP info.
I'm not sure what to do from here. I checked the fuel pressure 12psi (idle and load) Vacuum appox. 18 (idle) Voltage seems good. You said the Injector spray pattern looks good. I have two separate chips from Howell made for the 4.2 and it runs the same on both. WinALDL data seems to look ok. I swapped out the coil and the ignition module and it made no difference. At this point I don't even have the EGR or any of the California emission hooked up (to rule out vacuum leaks in any of those components.) It runs the same either way. I'm not sure what to try next. Rebuild TBI? Clean or get new Injectors? Any ideas? Thanks, Scott |
What's your main concern right now?
Have you logged data recently with BLM table? If the fuel is fairly close then that's all the system does and your problem is with your engine/jeep. What base timing are you running. If fuel only then you should be set around 10*
My main problem is that it doesn't run right, especially after it warms up. I can drive along at 1800rpm ish, up hill or level surface and it will backfire. I know there's a lot more power to be had.
The engine was rebuilt approximately 1000 miles ago and ran good before the swap. I don't have any error codes or check engine light. I did the screwdriver to the injector and ear test. The injectors sound the same and good. The base timing is set at 10. The more I look at it I would say the idle is even a little rough. The I6 should be very smooth at idle due to the nature of the engine. I believe there's something wrong that when fixed will bring this all together. Scott |
Was the only thing you changed the carb to TBI or did you change the distr also?
The one blm data file I saw looked pretty good. So that tells me you may have other problems. Have you hooked up a timing light and watched the timing as you rev it up? Are you running ported vacuum or manifold vacuum to the vacuum adv? I would recommend the ported vacuum. Check the parts required FAQ for the correct port to hook it to. Also make sure the vacuum adv is working by applying vacuum to the hose and make sure the timing goes up. Base timing is set with the hose disconnected and plugged.
I think I have had a timing light on it as it was revving, but I'm not sure. I'm going to go do that here in a few. I'm even going to put some tape on the Harmonic Balancer to extend the timing marks. The distributor is hooked up to ported vacuum. I connected it to the non ported plug once just to see if it made a difference. It was quite funny, every time it a cylinder fired, the vacuum would cause it to advance really far, then the next cylinder would miss. I will move my vacuum gauge to the ported port when I check out the timing advance. |
| 110 , 4.2 , 727 , aftermarket , binderplanet , cap , distributor , faq , faq's , find , fuel , hei , jeep , light , performance , power , rebuild , rich , start , tach , tbi , timing , vacuum , vacuum advance , website |
| TBI planing stages | BO185 | Injection Tech | 3 | 07-19-2011 11:35 PM |
| a call for help from overseas - tbi conversion going wrong | kingcrunch | Injection Tech | 16 | 07-14-2011 09:46 AM |
| Manifold adapters for TBI | Bill usn-1 | Injection Tech | 27 | 06-28-2011 12:29 PM |
| TBI running wayyyyy toooo rich | 65chevy4x4 | Injection Tech | 16 | 07-15-2007 12:40 PM |
| Christmas in September.... Affordable's TBI kit is in hand! | Damian Grihalva | General IH Tech | 17 | 09-27-2004 12:20 PM |
