Old 08-05-2011, 05:08 PM
rbelflower rbelflower is offline
Default Re: Fuel range of Scout II?
When I had my 19gals tank, I would go 190mils and put about 16-17 gals back in. I didnt like to push it more unless I had my Jerry can filled on the back.
I can now go 400 miles on my 33/35gal tank and dont get too worried.
I have pushed it to 450 once, but I was a little nervous.
Rob
76 Scout II
345/700R4 Auto/Dana20
Dana 44 F/R
Hardtop/Soft top
67 Scout 800
152 stick to be modified
Hardtop/Soft top (soon I hope)
Old 08-06-2011, 01:07 AM
Erik VanRenselaar's Avatar
Erik VanRenselaar Erik VanRenselaar is offline
Mighty:
You say you have 33" tires on the Scout. Is your speedo/odo accurate? You can easily verify it with a GPS unit. I'm assuming you're calc-ing your mileage with the odometer.
7 mpg city is poor for a Scout II w/ V8. Mine will give at least 10-12 mpg around town (w/ a light right foot), and 14+ on the highway.
'75 & '76 Scout IIs
Amateur radio operator, General Class - K6IHC
Work Smart, Not Hard...
Old 08-17-2011, 08:47 AM
Mighty Mighty is offline
Well, I'm back now... Scout performed like a champ. Only issue I had was a strap ripping free from my bikini top (now being replaced).. Well and one other minor issue; The T-19 isn't a happy downshifter and finding 3rd for some of the passes became a pita. I found myself double clutching and rev matching to get it to slip in (and it'd want to pop out again if I let off the go pedal abruptly).
The speedo is fairly close judging by the roadside radar signs. Just three mph high. Speedo says 60, radar says 57-58. Son's garmin confirmed it's fairly accurate.
I was able to cruise normally around 70mph, still had power to pass slower RV's & semi's and so forth. Again, we're talking high country, mountains, and high plains.
Didn't do much wheeling... just some scenic stuff. Next mod I think will be three seat belts on the rear bench (family of five here). It's wide enough, but only two straps. We did ride 'illegally' for a couple of these excursions.
Mileage was 10.5 mpg and the best I saw was 12.7 mpg. (Didn't track it though on the downhill way home). On the way up, I filled pretty often. On the way back, I pushed that comfort zone a lot more and did about half the stops.
Old 08-19-2011, 02:04 PM
Just got the replacement bikini top and upgraded to a family top...
B-DCo was great to work with. It's also a D&C Extreme custom cage if anyone is wondering...
2300 , 345 , 392 , cam , colorado , diesel , fuel , fuel gauge , fuel tank , fun , gas , hot , idle , ignition , poor , question , scout , scout ii , sound , start , swap , t-19 , truck , wide
Help on Fuel Tank / Fuel Line Replacement on a 1980 Scout II shanewbbr General IH Tech 5 11-07-2010 06:14 AM
CJ-10 SD-33 / Scout SD-33 Differences CareyWeber Diesel Tech 87 01-10-2008 07:32 PM
