Go Back   Binder Planet Forums > Special Interest Groups > Restoration Purists
Old 07-22-2011, 12:26 AM
Robert JetFxr's Avatar
Robert JetFxr Robert JetFxr is offline
Default Tony's Scout
Tony contacted me to do a rebuild for him on a yet to be named 66ish Scout. We chatted several times so I got a feel of what he was looking for in a Scout. So he bought a 66 Scout that was a little unusual in the fact that it is an 800 with a fold down windshield, it is rust free for the most part but it is rough. She has been sitting for a while, and someone has done a SOA and hacked the inner fenders. After RMIHR we will be pulling the body and sending it out for meadia blasting, then it will go over to a friends shop for some repair work before it heads to paint. Tony is looking to have it painted IH red with a white top. There will also be a lot of powder coating going on so it will have a fighting chance in the east coast winters. Stay tuned this will be a very stock kind of rebuild, here are the first pictures Scout showing up here in Montana.
Edit. How could I pass on this last picture heading for Pa.
Robert AKA Jetfxr
RIP Ricky you are missed.
Did you check the green wire?
1973 Travelette ton axles on 35s
1977 SSII Just a little modified ;o)
1980 Scout with 375hp LS1
Old 07-23-2011, 01:05 PM
Oil Scout Oil Scout is offline
Default Re: Tony's Scout
Any chance that is a Comanche Scout hood on that psuedo 66?
Old 07-27-2011, 11:01 AM
Yep looks like one to me. I will also have to install a windshield hold down loop because this rare bird is a 800 with a fold down windshield. Chcek the brackets are a little different than a Scout 80. International truely did build what ever you wanted I think, it amazes me to see the differences you run into in the same models.
Robert AKA Jetfxr
Old 07-27-2011, 11:09 AM
Here you can see some body damage to the nose of this Scout. While I was at RMIHR I stopped by Phil Conrod's and picked up a new nose, the cost of body work and also the fact that the newer one will not have a ton of filler makes it a no brainer.
Here also you see the inner fenders, someone cut the snot out of them at some point in this poor girls life. The repair will be a little tricky so that the repair will not be an eyesore from eather side.
Robert AKA Jetfxr
Old 07-27-2011, 11:16 AM
Here are a couple areas of consern on the rear bed, looks like over the years people have drilled many many many mounting hole for God knows what. I will be welding all of them up and have to blend out both sides to have a good look when this Scout is completed.
Also you see the end cap, we will be metal working this. In the past filler was used but you see here there was way to much. The filler is to smooth over a repair NOT to do the repair. The deal is when done wrong it looks like this, falling off
Robert AKA Jetfxr
Old 07-27-2011, 11:24 AM
As we progress with this project one of the issues that we will be addressing is a SOA that was done in the past. When we lift off the body and start the chassis rebuild we will be correcting this. Also we will be removing shock mounts that were welded on along with some sort of winch mount thing.
Robert AKA Jetfxr
Old 07-27-2011, 11:30 AM
Last pictures for now, this Scout has a found a place were all Scouts find love and attention even if it is the ~wrong~ kind
Robert AKA Jetfxr
Old 07-27-2011, 08:23 PM
db1115's Avatar
db1115 db1115 is offline
Very cool Robert. Thanks for sharing the work.
Davis
Old 07-30-2011, 02:08 PM
AJCDDS AJCDDS is offline
There is a question about the original hood. It was replaced with a newer 800 ... the original had an air intake cut into it. The new one looks the same except for the missing IH logo on the front and the windshield hold down loop. Tony
Old 07-30-2011, 09:09 PM
Stan Lazeski Stan Lazeski is offline
Tony, Glad to see your Scouts resurection has started! We are all looking forward to meeting you, hope you still plan to come up in August for our IH picnic. We also will be planning a road trip down to Williamsport sometime in the fall. Keep in touch. Stan
800 , body , build , international , montana , paint , part , pictures , poor , project , pulling , rare , rebuild , red , repair , rmihr , rough , rust , scout , scout 80 , shop , soa , top , windshield , work
Scout II engine swap question. mntgoat General IH Tech 30 01-31-2005 09:05 AM
