Old 07-09-2011, 07:20 PM
xsmokey11499x xsmokey11499x is offline
Default White foam in radiator?
Please Tell me It's not a headgasket. or head..
there is NO water/milkyness in my oil. and no oil in my coolant
But there is white foam in my radiator.
I just recently drained out the Water that was in there, And Added Antifreeze.
Truck does NOT overHeat.
73 1210, 345,4spd. 2wd.
'73 IH 1210 Pickup 2wd. 345. 4speed
Old 07-09-2011, 07:25 PM
76 xlc 76 xlc is offline
Banned
Default Re: White foam in radiator?
Did you flush system? Could a PO flushed system? Was system thoroughly flushed with water? What kind of coolant?
Old 07-09-2011, 07:47 PM
dont know anything about the PO. Except he sprayed the truck, with house paint -_-.
When I put the antifreeze in, I just opened the drain plug
let the radiator drain out. started the truck for a minute Then shut it off.
The PO was running Straight Water.
Also I bought The Auto zone brand Antifreeze. the cheapest one... $11
the truck also doesn't lose any coolant, So maybe it's just the antifreeze or something boiling ?
Will it harm the truck if I drive it this way.
Old 07-09-2011, 08:43 PM
Okay so I drained the radiator again drained as much as I could out. and put straight water in there, Now the foam Is Real Minimal. so I'm thinking Too much antifreeze!
It wasnt a 50/50 Jug. that I put in
Old 07-09-2011, 10:03 PM
GoNavy007's Avatar
GoNavy007 GoNavy007 is offline
Send a message via AIM to GoNavy007
Oh boy... Keep checking and if it doesn't come back maybe you're okay. I think you have a busted head gasket though. PITA...
Old 07-09-2011, 10:37 PM
I sure hope not! It doesn't over heat at all, no oils in the coolant, no coolant in the oil.
not losing coolant anywhere, But if it is a blown head/Headgasket I'm going to this
Old 07-09-2011, 11:03 PM
scoutboy74's Avatar
Pre-mixed coolant is a waste of money. Some people run as much as a 70/30 mix with no ill effects. The system likely was not fully purged of air and/or there were contaminants in the coolant. Observe the coolant in the top of the radiator with the cap off while the engine is running. See any bubbles? Bubbles are a pretty good indicator of a blown head gasket.
Trever Whetzel
Fat White Boys
Binder Recovery
& Rehabilitation
SHOP NORTH
Old 07-09-2011, 11:29 PM
GoNavy007's Avatar
I had a blown head gasket in a 1986 Dodge Ramcharger once. I didnt do anything about it for a while because I bought the car for $450 and didnt care. It started as just the white milky stuff in the coolant and nothing bad in the oil. 1000 miles later I was putting in a 1/2 quart of oil every time I filled up on gas. 2000 miles later I had 6 bent up pushrods and 2 that were pushed straight through the rocker arms. I got much better gas milage running it as a 4 cylinder though! I got 17 mpg when I towed a car from NC to MD. Eventually it got so bad my radiator emptied itself through my exhaust in 20 minutes of driving so I'd have to stop and fill it up a lot to get home. Anyway, I eventually pulled the heads and thats when I discovered the push rod and rocker problem. I also had two 1/2 inch gaps in one of my head gaskets. The Dodge 318 is a tough engine, but I digress...
I think it's a blown gasket. Have fun!
Old 07-10-2011, 02:08 AM
Well I don't hav3 no milky in coolant just tons of foam after I put antifreeze in
Old 07-10-2011, 03:24 AM
Greg R's Avatar
Greg R Greg R is offline
More than likely you did not burp all the air out before you started it.
With that, the pump will agitate a lot of the trapped air into foaming the coolant.
Try parking the rig nose up a slight angle to aid the air to escape when you refill the system. Another thing to check is the burp hole in the thermostat housing, they usually are rusted shut when they're this old.
Sailor Jerry is a good foam buster too
69 800
266 V8/4spd & D18TC/OD
4.27 D30/ D44
'56 S110 240 I6/4spd
'71 1210 345 V8/4spd 2WD
'67 Travelall BG246/4spd 2WD
100 , 1000 , 1210 , 2wd , 345 , air , antifreeze , blown , bus , cap , coolant , disc , engine , gasket , head gasket , oil , paint , radiator , scout , thermostat , top , truck , water , xlc
Johnny Lightning to do a Scout model! Mike Moore General IH Tech 73 12-12-2012 07:01 AM
Installing RND Radiator TheGoldenGreek General IH Tech 16 08-18-2011 11:24 PM
Radiator Mounting Blathering Eddie Diesel Tech 6 02-06-2008 05:30 PM
White foam inside valve cover clint larson General IH Tech 20 01-28-2008 12:05 AM
