I need to replace the door lock cylinder on my scout. I have the square post part removed from the door, but I can't figure out how to get the actual cylinder out so that I can put a new one in. Any suggestions? I bought the keys and locks in the link to replace the old ones. http://www.superscoutspecialists.com...travelall.aspx
GSA 1968 Travelall 1100C with barn doors, PTO winch, skid plates,T-98, and a BG265. |
Check with a locksmith. One should have a "master" key that can remove just the cylinder or core. It comes right out, and the new one goes in easy peasy.
69 800 266 V8/4spd & D18TC/OD 4.27 D30/ D44 '56 S110 240 I6/4spd '71 1210 345 V8/4spd 2WD '67 Travelall BG246/4spd 2WD |
Its alittle fun to do,in the pictures you have,the one shows the three parts that stick out with holes above them.In the middle hole(this is on pickups that use the same core,so yours should be the same) you should see a tab with a 1/2 circle cut out of it,you need to pull this toward the outside,the core should now slide partway out(this tab goes in the groove on the new cylinder)now in one of the other 2 holes you will need to push in each tab one at a time while pulling core out,I just did this 2 weeks ago.The other way is to drill the center out with a ssmall drill bit getting larger till the core falls to peices.
| 800 , cylinder , door , fun , key , lock , master , part , parts , pickup , pictures , pulling , removal , scout , scout 80 , scout 800 , travelall |
| Scout 800 Windshield Glass Removal | 800bman | General IH Tech | 5 | 03-20-2011 07:43 AM |
| Front Locking Hub Removal Scout 800 | paulh08 | General IH Tech | 2 | 12-12-2009 10:08 AM |
| 1980 Scout II trade for v8 800 | ihscoutmatt | North Texas Binders | 0 | 11-17-2009 10:24 PM |
| scout 800 ball stud removal ? | cartwright | General IH Tech | 6 | 11-13-2004 08:57 PM |
