Old 06-01-2011, 10:06 AM
bjw27's Avatar
bjw27 bjw27 is offline
Default Dana 27 & 30 disk brake kit
Anybody install this kit? http://compare.ebay.com/like/3102227...=sbar&_lwgsi=y opinions?
Thanks!
Old 06-01-2011, 10:29 AM
radar232's Avatar
radar232 radar232 is offline
Default Re: Dana 27 & 30 disk brake kit
For the money I would rather find a Dana44 with disc brakes already installed...
1962 Scout 80 4X4. >Stock Modified<
80/800 Hula Girl Club
Old 06-01-2011, 12:42 PM
BRADLEY NORTON BRADLEY NORTON is offline
I did the same conversion on my 62 it was easy to set up and all the parts were from the junk yard and the only new parts were the scout II rotors. I think i spend right around 150.00 for the parts
Old 06-01-2011, 01:27 PM
bjw27's Avatar
what was the specific vehicle and front end that the jy parts came from?
Old 06-01-2011, 02:50 PM
Gary Billings's Avatar
Gary Billings Gary Billings is offline
Send a message via AIM to Gary Billings
There's a few ways to do it cheaply. Take a look at this thread here:
http://www.binderplanet.com/forums/s...t=45700&page=2
The disc brake conversion starts about halfway down. I did mine with a mixture of Scout II drum brake Dana 30 spindles, Scout II Dana 44 wheel hubs & rotors, and Chevy/full size Jeep calipers & caliper stands.
-Gary
El Guapo: Jefe, would you say I have a plethora of Scouts (and two Travelalls and a Pickup)?
Jefe: Yes, El Guapo. You have a plethora.
Old 03-14-2012, 10:58 PM
rlireland's Avatar
Default re: disc brake kit
Yes! I just finished the conversion using the Horsepower Sales kit for the Dana 27/30.
I gathered information from Gary Billings and others who have used junk yard parts to do the conversion. I weighed what it would cost in time for me to find the right parts and pull them off. I also took in to account the possibility of getting something home and finding out it wasn't the right part or didn't fit. I factored in the costs of having the rotors resurfaced and pruchasing new disc brake pads and flexible lines. It was worth it to me to just purchase the bolt-on kit from Horsepower Sales.
I'm not saying this is the best way to go for everybody. Others may have some or all of these parts laying around their garage or be more confident in their abilities to make used parts fit and function correctly.
That said, the kit was complete and everything bolted on without a problem. The instructions are pretty clear and easy to follow, although if you have ever done any work on a FA21 axle, you could probably do the conversion without them.
The kit includes the hub/rotor assembly, caliper mounting bracket, a gravel shield, loaded caliper assemblies, Timken bearings, longer length grade 5 bolts to attach the brackets, flexible braided brake lines, clips to secure the lines to the inner fender, and hub gaskets.
I purchased a rebuilt Scout II master cylinder for $15 from O'Reilly's. I needed to bend new brake lines from the prop valve to the M/C since the ports are on the opposite side from the stock 800 M/C. The inner fender also needs to be notched to provide room for the longer M/C.
The braided flex lines seem to be a little short though. Although they are the same length as the stock lines, the way they attach to the calipers takes away several inches. They'll work fine on the street but will probably get stretched too far in any articulation situation. They will, of course, be too short for a spring over axle installation.
Overall, I'm very happy with the kit and feel it is worth the price if you don't want to spend the time parts hunting and pulling.
Roy
ID:	66690   Click image for larger version
ID:	66691   Click image for larger version
Old 03-15-2012, 08:22 AM
radar232's Avatar
Default Re: disc brake kit
Well put Roy.
I don't remember posting on this thread a while back but I now know a Dana 44 front axle is a bit to much for my little Scout 80. I've been seeing parts kits all over ebay for
D-27 and D-30 closed knuckle front axles at around $600 bucks and in my opinion its well worth it.
I do think you can get a disc/drum master cylinder small enough to fit cause I've seen 'em in a few pictures here and there but could never figure out where or what they came from.
Old 03-15-2012, 10:34 AM
robgimmel's Avatar
robgimmel robgimmel is offline
If you put this kit on do you have to change the master cylinder or can you use the old one? I've been thinking about it myself.
Rob Gimmel
68 800
3 spd trans
152 engine
A man who has nothing which he cares about more than his personal safety is a miserable creature who has no chance of being free, unless made and kept so by the existance of better men than himself.
John Stewart Mill
Old 03-15-2012, 08:04 PM
rlireland's Avatar
According to Gary, the stock 800 M/C and prop valve can be used with the disc set up. I found that a rebuilt M/C was cheaper than the rebuild kit (go figure) and it has a lifetime warrantee, so I went with the Scout II M/C just to upgrade things a little.
I was concerned about using the stock pushrod with the new Scout II M/C. The stock 800 set up has a retainer and a "C" clip that secures the pushrod to the cylinder. But the Scout II cylinder doesn't have the groove for the "C" clip so I just removed the retainer and clip and used the pushrod by itself. It doesn't appear to have any problems.
Roy
Old 03-16-2012, 11:29 AM
Lowell Lowell is offline
Send a message via AIM to Lowell
Nice Roy! Looking forward to checking the conversion out at the AZIHR next weekend.
Lowell
62 scout 80, 75 Scout II
Sonora Desert Scout member
800 , axle , bearings , binderplanet , brake , brake conversion , brakes , caliper , conversion , dana 27 , dana 44 , disc , disc brake , disc brakes , find , front , front end , full size , master , parts , pictures , scout , scout ii , tach
Dana 30 to Dana 44 swap. Need brake conversion information Julian 537 General IH Tech 2 09-19-2010 03:31 PM
TeraLow kit for Dana 20? Erik VanRenselaar General IH Tech 16 01-05-2006 12:31 AM
Dana 30 Disk Brake conversion, again slydog General IH Tech 7 10-19-2005 05:41 PM
IH Dana 60 Rear Disc Kit... Doug Shailor General IH Tech 23 05-18-2005 07:01 AM
Best place to get a Dana 300 rebuild kit? Reeve General IH Tech 5 01-18-2003 09:09 PM
