Old 06-20-2011, 06:03 PM
JeepsAndGuns JeepsAndGuns is offline
Default Re: Multi-Port Fuel Injection
Nice install and glad its working out great. One question, just out of curiosity, what throttle body is that? I cant really get a good view of it from the wires laying on it in the pics, but it looks kinda like a TBI unit with the injector pod removed.
Old 06-20-2011, 06:14 PM
It was buried in the first post.
The system consists of an aluminum RPT manifold from IH Only. For specifics on installing the RPT manifold see this FAQ The rest of the component parts are from the wrecking yard.
The wiring harness is from a 1988 2500 Chevrolet pickup truck. The distributor is from a late model Buick(stick with the chevy distr) and is the seven pin large cap. But the rotor plate had to be reindexed since it was a CCW not CW rotation distr. This changed the rotor phasing. I had a machinist adapt this distributor top onto an existing 4 pin "Willis" large cap distributor that was in the truck already. The pickup was also changed at this point to the Chevrolet style.
The Holley throttle body that will be used in this conversion is from a 1997 V8 Jeep.
The computer is a 7427 out of a 1994 Astro Van CPI 4.3 V6. For specifics on what mods need to be done to use this PCM with a MPFI system see this FAQ.
More information to follow. This will wet your appetite hopefully.
Old 06-20-2011, 07:20 PM
HA, Thats what you get for not re reading the first post. I had read it when he first posted the thread, but didnt when I looked at it today. All I read was the newer posts with the pics.
Old 06-20-2011, 07:22 PM
You can see several we picked up in this initial MPFI thread.
Old 06-20-2011, 10:45 PM
gravedigger's Avatar
gravedigger gravedigger is offline
I will post some new pics of the installation in the next few days with some close ups of the components. Gotta install my blingy new clear cap and clean/polish the throttle body, etc...
1962 C130 4X4 Crewcab, 392 V8 Multi-Port Fuel Injection, 4l80e trans. w/married 205
1964 Scout 80 4X4 Campermobile 152/ 3speed w/overdrive
1965 Scout 80 4X4, 196/ 4spd, snowplow equipped
1977 SS II Fuel Injected
1980 SSII
Cub Cadet 125 W/Hydraulic Assist, 48" Mower, Front Blade, Rototiller
Old 06-22-2011, 10:43 PM
Here are a couple pics of the nearly complete system. Still need to polish the Throttle Body, etc...
1980 SSII
Old 07-02-2011, 11:34 PM
binderbound's Avatar
binderbound binderbound is offline
This is a beautiful truck. I had the pleasure of seeing it in person at the just IH show a few weeks ago. The FI install is super clean and the whole truck is impressive. If anybody gets the chance to see this rig in person, dont pass up the chance.
Now that the system has been on for a few weeks and you have put some miles on it, what are your thoughts? MPG numbers? Anything your not happy with or would do different?
Co-founder and lifetime member of the IHSTO
Stick and Stones and Scouts and Bones
facebook.com/hardenedways
Scout out America
Old 07-20-2011, 06:21 PM
A quick update. We took the truck to the Binder Bee in Brooks Oregon this last weekend and it performed beautifully on the road down and back. Average was 12 MPG with one run being 13.08 MPG this was done when my average road speed was about 60 MPH.
I will be taking this truck up to the Chilliwack I.H. Super Show http://www.scoutpluss.com/ih-show-2011/ .
Hope to see a few of you there.
Chris
1980 SSII
Old 09-25-2011, 08:05 AM
Hows the system doing? I have a couple questions.
Your running the dodge/jeep TB, did you re use the tps, iac, and map from that TB, or did you adapt gm sensors on there? From the pics, it kinda looks like you re used the dodge/jeep ones. If so, then I am guessing they are compatable with the gm system? They put out the correct voltage/signals?
And next, what fuel pressure regulator did you use? It kinda looks like a aftermarket one from the picture. Is it set for one pressure, or did you vaccume refrence it? And what pressure are you running?
Thanks.
Old 09-25-2011, 11:02 AM
The system is running great. You are correct I am running the sensors that were mounted on the throttle body when pulled from the donor vehicle. Only the IAC needed to have the wires switched around, but the IAC is still the same as the GM otherwise. The fuel pressure regulator is an inexpensive one off EBAY and cost about $40.00 if I remember correctly. No need to spend big bucks when cheap will do. Regulator is set at about 42 psi. It does have a reference connection port if I decide to later add a turbo or....
1980 SSII
196 , 4x4 , aluminum , axle , body , cap , carb , conversion , distributor , engine , frame , fuel , fuel economy , harness , holley , international , parts , pickup , rust , short , throttle , top , truck , wiring , wiring harness
Will's Fuel Woes Solved? W.James Diesel Tech 1 11-03-2011 08:11 PM
Project: Scout 80 Electric Fuel Pump jtownley General IH Tech 13 03-28-2011 12:39 PM
Mechanical fuel pump diagnosis questions. ruderunner General IH Tech 13 09-22-2010 05:52 AM
Odd 2300 Holley problem. Gun Line General IH Tech 40 07-12-2009 05:50 PM
Fuel Gelling/Wax??? RD Durham Diesel Tech 44 01-27-2008 10:24 PM
