Old 05-30-2011, 11:30 AM
gravedigger's Avatar
gravedigger gravedigger is offline
Default Multi-Port Fuel Injection/4L80E upgrade
This thread is dedicated to the installation of a multi-port fuel injection system onto my 1962 C-130 4X4 truck. A short bit of history. This truck is the first International I purchased. A friend of mine saw it on the side of the road near Riverside, California, and told me that "Internationals are a great American built truck and that if you want a truck that will last......" needless to say I went and bought it. I have since then taken the truck completely apart and serviced every component part including rebuilding the engine, axle's. I sand blasted all the sheet metal including the frame. Zero Rust primer on the frame with clear over the top gives a nice mat looking finish. Used DP 40 LF to seal the sheet metal and top coated with acrylic enamel.
The truck gets about 8 mpg with the Edelbrock 1406 carb. I will post fuel economy numbers once the fuel injection is installed up and running.
The system consists of an aluminum RPT manifold from IH Only. For specifics on installing the RPT manifold see this FAQ The rest of the component parts are from the wrecking yard.
The wiring harness is from a 1988 2500 Chevrolet pickup truck. The distributor is from a late model Buick(stick with the chevy distr) and is the seven pin large cap. But the rotor plate had to be reindexed since it was a CCW not CW rotation distr. This changed the rotor phasing. I had a machinist adapt this distributor top onto an existing 4 pin "Willis" large cap distributor that was in the truck already. The pickup was also changed at this point to the Chevrolet style.
The Holley throttle body that will be used in this conversion is from a 1997 V8 Jeep.
The computer is a 7427 out of a 1994 Astro Van CPI 4.3 V6. For specifics on what mods need to be done to use this PCM with a MPFI system see this FAQ.
More information to follow. This will wet your appetite hopefully.
Oh by the way this conversion is made possible with the expert assistance and technical wizardry of Bill Hamilton from Hamilton Fuel Injection fame.
Stand by.........
1962 C130 4X4 Crewcab, 392 V8 Multi-Port Fuel Injection, 4l80e trans. w/married 205
1964 Scout 80 4X4 Campermobile 152/ 3speed w/overdrive
1965 Scout 80 4X4, 196/ 4spd, snowplow equipped
1977 SS II Fuel Injected
1980 SSII
Cub Cadet 125 W/Hydraulic Assist, 48" Mower, Front Blade, Rototiller
Old 05-31-2011, 10:05 PM
Default Re: Multi-Port Fuel Injection
Spent memorial Day weekend working on the installation process. Completed initial routing of the wiring harness. Mounted the fuel pump, feed lines and return line. Installed fuel pressure regulator. Picked up a piece of 1/2" plate aluminum from the recycle and fabricated an adapter for the throttle body.
Installed the throttle body, injectors and fabricated some slick fuel rail adapter plates to make mounting the fuel rails easier. A piece of an old road sign performed nicely. For the time being brass fittings were installed on the fuel rails and plain F.I. hose was used to route the fuel system. Once all is up and running perfectly, then some "Bling" will be added to spruce it up.
1980 SSII
Old 05-31-2011, 10:12 PM
Continuing work on the wiring and re-pinning the PCM connector plugs proved to be an arduous task, but perseverance was the ticket to get the work done on Sunday. Installed O2 sensor and the wiring for the fuel system. It was a bit like "Brain Salad Surgery."
1980 SSII
Old 05-31-2011, 10:16 PM
The truck came to life at about 8:30 Sunday evening. Now the tuning begins.
Don't change that channel......
First run.
http://youtu.be/pBmNK7eEOuU
After a little chip tuning.
http://youtu.be/eEkXOc8gjDs
To keep us on task the shop foreman kept sticking his nose in to make sure we were working.
1980 SSII
Old 06-07-2011, 10:22 AM
The system is up and running. The 1406 that I had installed in 2004 and had finely tuned was no comparison at all to this Multi-Port conversion. Still need some more tuning and finishing up touches, but I am extremely pleased with the conversion and am looking forward to getting some numbers up on the board in regards to MPG and further performance data.
I am in the middle of doing an alternator install on the truck and powder coating the valve covers and thermostat housing. Going to install an 89 Caprice air cleaner and hook up the IAT.
The more sensor data, the more accurate the tune.....
Chris
1980 SSII
Old 06-07-2011, 11:26 AM
Jeff Bade's Avatar
Jeff Bade Jeff Bade is offline
Administrator
Send a message via ICQ to Jeff Bade Send a message via AIM to Jeff Bade Send a message via MSN to Jeff Bade Send a message via Yahoo to Jeff Bade
Great Write up..
Nice Pics too..
Especially your dog who obviously is doing all the chip programming for you..
-Jeff
1980 Scout II Midas
1969 Travellall
"all growth is a leap in the dark, a spontaneous,
unpremeditated act without benefit of experience."
In Wisdom Of The Heart - Henry Miller
Click Here to visit the Binder Planet IH Knowledge Base
Old 06-07-2011, 11:38 AM
Texas is a great dog. He lives the consummate dog's life. No worries in the world, just guarding his masters property and keeping all the I.H. iron safe and secure.
1980 SSII
Old 06-12-2011, 08:09 PM
EagleMark EagleMark is offline
Banned
Nice truck!
Sweet install as well, glad to see your making the change to a modern charging system as EFI likes/requires a good clean supply of 12 volt power.
The Caprice air filter is a very trick item I came up with for Scout II about 10 years ago. It was the only one I could find that was low enough for hood clearence on the Scout II. But you have a lot more room so the door to JY late model GM air filters with tubing for cool air and hot air are probably anything. HTH!
Old 06-15-2011, 12:16 PM
The truck is up and running beautifully. More tuning still needs to be done, but I am totally impressed with the change in engine operating characteristics. My son says it sounds like a ralley car now. I will have MPG stats as soon as the truck sees some driving on the highway etc..
Will post some more pics tonight that details the system in a near completed state.
Saw that Bill has some stuff listed for sale in the machine shop forum. looks to be decent prices, he puts lots of work into everything that is produced.
http://www.binderplanet.com/forums/s...d.php?t=102989
1980 SSII
Old 06-20-2011, 12:26 AM
Drove to the Binder Bash this weekend with the wife and son. Avg. was 12 MPG with the best run being 13 mpg going about 60 mph on level terrain. The drive time was about seven hours each way so the stats are pretty good. With more tuning etc.., we may see some slight improvement. The best I got with the edelbrock on this motor was about 8 mpg and it was a new carb that I tuned to its best performance abilities. Big thumbs up for MPFI !
1980 SSII
196 , 4x4 , aluminum , axle , body , cap , carb , conversion , distributor , engine , frame , fuel , fuel economy , harness , holley , international , parts , pickup , rust , short , throttle , top , truck , wiring , wiring harness
Will's Fuel Woes Solved? W.James Diesel Tech 1 11-03-2011 08:11 PM
Project: Scout 80 Electric Fuel Pump jtownley General IH Tech 13 03-28-2011 12:39 PM
Mechanical fuel pump diagnosis questions. ruderunner General IH Tech 13 09-22-2010 05:52 AM
Odd 2300 Holley problem. Gun Line General IH Tech 40 07-12-2009 05:50 PM
Fuel Gelling/Wax??? RD Durham Diesel Tech 44 01-27-2008 10:24 PM
