Old 04-19-2011, 01:28 PM
kmad86 kmad86 is offline
Default Rear Dana 27 in a Scout 80, what's the setup lenght?
I've been trying to get the rear setup in the scout and have gotten close. I am running into one last problem. The axle is just a little too long.
I think what's happened is the previous owner put a different axle on one side because it's been resplined and it's too long, by about 1/8th inch. This is after I went completely through the axle and ordered all the right parts and fixed the botched up job from the previous owner. I have about 300thousands shim on it to get it to work, but that isn't right. So I think I am going to have a shop grind the axle to the right lenght.
I need to know what the length of the rear axle is from the back of the bearing to bearing. Any idea where I might find this information?
65 Scout 80 (Trying to get going)
69 Scout 800 (Parts rig, maybe I have something you could use, PM me)
Old 04-19-2011, 07:29 PM
WRENCH MAN's Avatar
Default Re: Rear Dana 27 in a Scout 80, what's the setup lenght?
Does it have a Power Lok in it? if so the thrust shoe that goes between the axle and center pin may be out of place?
68 Rambler American
72 1210 4x4
77 ScoutII
97 JEEP TJ
99 Yamaha YFS 200 (248)
Old 04-19-2011, 08:25 PM
I don't believe that's the case. Isn't this axle too old to have that?
Old 04-19-2011, 08:57 PM
Dana Strong Dana Strong is offline
I owned a stock '61 Scout with Powr-Loc, and yes, the spacer plug sat between the two axles.
Old 04-19-2011, 09:00 PM
timscout1's Avatar
timscout1 timscout1 is offline
If the axle is a powerlock the most common problem is the thrust blocks falling loose. On these axles the block are held in with a roll pin which wears with age and allows the 2 blocks to fall loose.
choose IH and fly with quality under your belt.
73 1210 4x4 Travelette 5 spd. 392
300 utility tractor
64 Scout 80-152/ weber 32/36
1955 IH RC180 cabover 7.3L
1947 IH fire engine GD233
1970 Fleetstar 2010 fire engine LV549
73 Scout2, 304.4 spd.
Member, Sonora Desert Scouts
Old 04-20-2011, 03:03 PM
The axle is so long now, when it goes in on one side, it pushes the bearing out on the other side.
How do I tell if it has powerlock? When I turn the wheel on one side, it goes the opposite direction on the other wheel.
Old 04-21-2011, 10:15 AM
If the opposite wheel turns in the opposite direction, either you have no PowerLoc or a very worn one.
Old 04-21-2011, 06:50 PM
Greg R's Avatar
Greg R Greg R is offline
Being a Scout 80, you have the offset diff right?
I'll bet you got 2 long axles instead of 1 long and 1 short, the long side being the driver's side. I can't say for sure at this point but IIRC the difference between right and left was around 3 or 4 inches. You also may have an axle from a later centered diff instead of a short one.
Call Mike at MR Scout, 541-935-3232; he can verify your details, and may have the correct axle you'll need.
69 800
266 V8/4spd & D18TC/OD
4.27 D30/ D44
'56 S110 240 I6/4spd
'71 1210 345 V8/4spd 2WD
'67 Travelall BG246/4spd 2WD
232 , axle , axles , case , dana 27 , find , grind , parts , plug , power , power lok , problem , rear , rear axle , roll , scout , scout 80 , shim , spacer , wheel
Dana 44 into Scout 80 Mastiff General IH Tech 19 06-10-2009 09:51 AM
Scout 80 - Rear Brake Hose jtownley General IH Tech 1 01-03-2008 02:34 PM
Timken #10 bearing rear axle? Brandon A. General IH Tech 17 05-04-2005 07:16 AM
Scout 80 axle upgrade???? SII?? chevy6scout General IH Tech 1 06-03-2004 04:13 PM
Scout 80 Rear end ? Matt Hoobler General IH Tech 3 10-19-2001 03:38 PM
