Old 04-17-2011, 05:42 PM
bindernut/gm bindernut/gm is offline
Default swapping powr locker
can I take a powr locker out of a 69 1100,or a 1970 800a(both are dana 44s) and put them in 1978 scout dana 44s.Thanks
Old 04-17-2011, 05:57 PM
Default Re: swapping powr locker
Yes with some extra parts,I am almost positive the pickup has different spline count,this means you need to change where the splines ingage..I would do it,power locks are the best in my mind.
Old 04-17-2011, 07:03 PM
Dennis Bernth's Avatar
I think the pickup would have the old style axles with the wheel bearing adjusters, so like Jeff said, the Powrlock would take some work to swap it over. The one out of the 800 should be the same though as long as it has flanged axles.
Old 04-17-2011, 08:28 PM
I can assume that a rear d44 locker can be put into a front d44.I would also assume that as long as the gear ratios are close(4:10-4:27) they would also be compatable.
Old 04-18-2011, 10:20 AM
Greg R's Avatar
Greg R Greg R is offline
What matters is carrier size, and spline count of the side gears matching the axles of the vehicle it goes into.
You are only changing carriers to go the Powr-Lok route. The original ring gear gets swapped from original to the donor so you will maintain a matched set in the 78. If the axle spline count of the donor axle and the receiving axle are the same, no problem; if the gear ratios are close,(with 3.73:1 being the break point), no problem. If the carrier size or side gear spline count of the donor aren't the same as the receiving axle, you are in for a total rebuild anyway.
69 800
266 V8/4spd & D18TC/OD
4.27 D30/ D44
'56 S110 240 I6/4spd
'71 1210 345 V8/4spd 2WD
'67 Travelall BG246/4spd 2WD
100 , 110 , 1100 , 1978 , 800 , 800a , axles , front , gage , gear , gear ratios , locker , parts , pickup , power , rear , rebuild , scout , size , swap , wheel , wheel bearing
Locking your Dana 44 Trac Loc, Part 1 MikeInMobile,AL BP IH Knowledge Wiki 0 09-27-2009 07:41 PM
Detroit soft locker help old blue 76 General IH Tech 5 07-28-2009 06:13 PM
locker swapping? m c woods General IH Tech 4 08-16-2005 08:28 PM
Swapping a Detroit EZ Locker Jason Call General IH Tech 7 12-26-2004 11:02 AM
soft locker Lecasta7 General IH Tech 1 12-15-2002 10:01 PM
