Old 03-13-2011, 07:47 AM
BioTex's Avatar
BioTex BioTex is offline
Default PTO Winch
I removed the winch from a S80 with the drive shafts. Since I'm going to sell it, I probably need to also remove the shift lever also.
What do I need to do to get the drive housing off. If there is a plate that bolts back on in its place, I don't have one, so that may be a proiblem.
Looking for some ideas as to what is involved while the TC is still installed.
Old 03-13-2011, 09:59 AM
IronMaiden's Avatar
IronMaiden IronMaiden is offline
Default Re: PTO Winch
Unbolt it and either bolt on the standard block off plate or make one out of a piece of sheet metal.
I don't know what transfer case you have, but when I took mine off of my NP205 when I got it, I just went to the junk yard and grabbed one off of a Ford.
Old 03-13-2011, 10:40 AM
truck mechanic truck mechanic is offline
if your talking about the plate that goes in place of the pto, there are onlt a couple different ones, most likely you have a 6 bolt, ant truck shop should be able to get you one, or a body upfitter would have them as take offs.
Old 03-13-2011, 01:06 PM
jeff rotella's Avatar
jeff rotella jeff rotella is offline
Are you talking about the PTO on the rear of a Scout 80 t/c?
-Jeff Rotella
body , pto , rear , s80 , scout , scout 80 , truck , winch
Rear Mounted Pto Winch michaeldimock General IH Tech 7 02-08-2008 10:44 PM
original PTO winch value? Albuq. Henry General IH Tech 2 11-12-2007 07:24 AM
Scout 800 PTO winch on a SII? Munchies General IH Tech 1 05-21-2005 02:03 AM
PTO Winch Question Deadduck General IH Tech 2 02-29-2004 01:36 PM
