Old 02-14-2011, 05:32 PM
ihbanana's Avatar
ihbanana ihbanana is offline
Default Cup Holder in my Scout
Does anyone sell a cup holder for the Scout II??? I have a bench seat, so I don't want the console version and I keep spilling coffee and Irish Creme everywhere!!!!
Old 02-14-2011, 06:15 PM
Mark B 70SR2's Avatar
Mark B 70SR2 Mark B 70SR2 is offline
Default Re: Cup Holder in my Scout
Here you go. put it right on the dash. It has a nice gimbal mount for off road conditions... http://www.go2marine.com/product.do?...F&WT.mc_id=gb1
......__________
.... |__________|
.[]<|0|_______|0|>[]
....|.... |.v....|.....|
....|___|.......|___|
Old 02-15-2011, 07:28 AM
JordanAMC's Avatar
JordanAMC JordanAMC is offline
There is always this option:
http://scoutparts.com/products/?view...oduct_id=17897
1971 Scout II - I need to to learn how to weld (or find a money tree) before she makes any more progress.
Old 02-15-2011, 07:40 AM
800bman's Avatar
800bman 800bman is offline
Send a message via AIM to 800bman
I kind of like that stainless one!
Old 02-15-2011, 11:16 AM
Robert JetFxr's Avatar
Robert JetFxr Robert JetFxr is offline
Look in the upper right corner. You can see my cup holder, you can get these at most any sporting goods store or even Wally World and mount them in several spots on a Scout. It's a water bottle holder for a bicycle
Robert AKA Jetfxr
RIP Ricky you are missed.
Did you check the green wire?
1973 Travelette ton axles on 35s
1977 SSII Just a little modified ;o)
1980 Scout with 375hp LS1
Old 02-15-2011, 01:33 PM
chickadee45 chickadee45 is offline
Me too!
Old 02-15-2011, 04:35 PM
800bman's Avatar
That bicycle bottle holder is a good idea too.
Old 02-15-2011, 07:48 PM
rbelflower rbelflower is offline
Walmart. They sell a cheap $11.00 cup holder that fits very nicely in the middle, if you don't have a bench seat.
The cups holders are even adjustable.
Rob
76 Scout II
345/700R4 Auto/Dana20
Dana 44 F/R
Hardtop/Soft top
67 Scout 800
152 stick to be modified
Hardtop/Soft top (soon I hope)
Old 02-15-2011, 10:28 PM
Mt Hood Carl Mt Hood Carl is offline
The PO of my Scout put a cheapo single cup holder on the (manual) tranny cover. It works perfectly and it's easy to reach.
Old 01-23-2012, 07:30 PM
cv_scout's Avatar
cv_scout cv_scout is offline
Here is my cup holder setup. I already had the gauge panel in place and wanted something that would connect to it with minimal work. My other requirements included durability, simplicity, versatility, and a setup that would match the rest of the truck.
There are three pieces to the cup holder assembly; two cut out of a 3” pipe and one made from a 3/16” diameter rod. I got the stock to make the pieces from a salvage yard and it cost $2 The rod is held by two nylon straps (for electrical wiring) and secured by small machine screws with stainless steel stop nuts and the hardware cost about $3 total.
The rod allows the cup holder to swing for hills and to accommodate tall water canteens. The pipes were slotted (opening up to about 3-1/2” diameter) to also allow for mugs and cups with handles. The pipe rings are 3-1/2” tall.
So the rod was bent in a vise and the pipe was cut with an angle grinder. All metal edges were de-burred with a file and the areas to be welded were ground bare. I used two tack welds on each cup holder behind the rod so they would be obscured from sight. After welding, the entire unit was sandblasted and then coated with flat black enamel paint to match everything else.
1980 Scout II Diesel - Hydroboost, EE, MB Turbo Housing, more in the works...
200 , cost , dash , electrical , ground , manual , mount , paint , panel , parts , roll , salvage , scout , scout ii , screws , seat , tire , tranny , truck , wanted , water , welding , wiring , work
Console Cup Holder v2.0 David Fulford General IH Tech 1 04-18-2008 08:00 AM
