Go Back   Binder Planet Forums > Special Interest Groups > Triple Diamond Trucks
JustIH Binder Bash 2013
  #11
Old 08-20-2012, 11:56 AM
Doc Stewart Doc Stewart is offline
Content Team
Default Re: Dual Rear Rims - Single Piece
Just have to change the hub itself. Remove the bolts holding the axle to the hub and pull the axle out. If it sticks, smack it smartly in the center with a BFH [big fine hammer] and it will pop loose.
Remove the nut, bend down the keeper and remove the inner nut. Now the hub will pull off. You may have to back off on the brake adjuster.
The hub unit is what you would change over to use 8 bolt rims.
That said, there are 6 x7.25 Budd rims [those with no locking ring] available. Sitting at my shop right now are a set of 6 x 7.25 bolt pattern 17.5 diameter with new road tires taken off a 68 Travelall 1200. I also had a set of 16.5 6 bolt rims on a 63 pickup many years back. Dodge and Ford also used that pattern.
Save yourself the expense by using a truck tire shop do do your tire changing. The only danger in lock ring rims is when they are being mounted. They don't bite during day to day use.
Doc Stewart
"Tough Old Geezer"
Charter member: IH Old Hippie Club
1300 , 2wd , axle , case , custom , fair , ford , loadstar , lock , number , parts , rear , rear axle , repair , rims , seat , shop , short , swap , tires , top , truck , wheel , wheels , work
Exhaust NewScoutin General IH Tech 5 08-09-2005 07:25 AM
Timken #10 bearing rear axle? Brandon A. General IH Tech 17 05-04-2005 07:16 AM
Single to Dual Circuit MC WesV General IH Tech 1 03-30-2005 09:49 AM
65-68 Travelall 2WD-4WD rear axle parts swap LeeC General IH Tech 34 05-22-2004 11:40 PM
need help with DUAL D20 tcases Todd J IH Scouts & Trucks of Oregon 49 04-07-2004 05:22 PM
